    How to load all RBS files ?
    8 Posts 4 Posters 3.2k Views 4 Watching
    • pingpinkP
      pingpink
      Hello everyone,
      I have some problems of loading my test plugin which is already scrambled for .rbs files.
      I don't understand the method to write .rb file to load all .rbs files in the folders.
      What should I write the loading code which I named it "cw_load.rb" ?
      There are many errors when I open in SketchUp 2014.
      This is the code in cw_load.rb
      #Sketchup;;require 'myFolder/myScript'
      Sketchup;;require 'CurtainWall_FStick.rbs'
      Sketchup;;require 'CurtainWall_FUnitized.rbs'
      Sketchup;;require 'CurtainWall_MainProgram.rbs'
      Sketchup;;require 'cw_archtoolbar.rbs'
      Sketchup;;require 'cw_report.rbs'
      Sketchup;;require 'cw_rubytoolbar.rbs'
      Sketchup;;require 'inputbox.rbs'
      Sketchup;;require 'CurtainWall/Components/Mullion_50/Mullion_50.rbs'
      Sketchup;;require 'CurtainWall/Components/Transom_50/Transom_50.rbs'
      Sketchup;;require 'CurtainWall/Components/Mullion_60/Mullion_60.rbs'
      Sketchup;;require 'CurtainWall/Components/Transom_60/Transom_60.rbs'
      Sketchup;;require 'CurtainWall/Components/Mullion_80/Mullion_80.rbs'
      Sketchup;;require 'CurtainWall/Components/Transom_80/Transom_80.rbs'
      • J
        Jim
        Something like..
        Dir["myFolder/*.rbs"].each do |filename|
          Sketchup.load(filename)
        http://ruby-doc.org/core-2.1.2/Dir.html
        • Dan RathbunD
          Dan Rathbun
          What about:
          require("sketchup.rb")
          require_all("MyFolder")
          I'm not here much anymore.
          • pingpinkP
            pingpink
            I try to do , but I still don't know how to load all rbs files. 😒
            require 'sketchup.rb'
            Dir["pathFolder/*.rbs"].each do |filename|
            $path_root = "C;\Users\Windows8\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
            Sketchup;;load $path_root + "CurtainWall_FStick"
            Sketchup;;load $path_root + "CurtainWall_FUnitized"
            Sketchup;;load $path_root + "CurtainWall_MainProgram"
            Sketchup;;load $path_root + "cw_archtoolbar"
            Sketchup;;load $path_root + "cw_rubytoolbar"
            Sketchup;;load $path_root + "cw_report"
            Sketchup;;load $path_root + "inputbox"
            or this method ?
            module CW
              # Menus and Toolbars
              unless file_loaded?( File.basename(__FILE__) )
                m = UI.menu( 'Plugins' )
              PATH    = File.dirname(__FILE__)
              # Load scrambled files.
              Sketchup;;require( File.join(PATH, 'CurtainWall_FStick.rbs') )
              Sketchup;;require( File.join(PATH, 'CurtainWall_FUnitized.rbs') )
              Sketchup;;require( File.join(PATH, 'CurtainWall_MainProgram.rbs') )
              Sketchup;;require( File.join(PATH, 'cw_archtoolbar.rbs') )
              Sketchup;;require( File.join(PATH, 'cw_report.rbs') )
              Sketchup;;require( File.join(PATH, 'cw_rubytoolbar.rbs') )
              Sketchup;;require( File.join(PATH, 'inputbox.rbs') )
            file_loaded( File.basename(__FILE__))
            In the plugin
            • pingpinkP
              pingpink
              I revised in a new way , but I can load only the rbs files outside the folders.
              Inside the folders are rb files as it called every time when opening SU 2014.
              In the 'scramble.bat' in part of folder , I wrote this way.
              scrambler.exe CurtainWall/Components/Mullion_50/Mullion_50.rb
              scrambler.exe CurtainWall/Components/Transom_50/Transom_50.rb
              scrambler.exe CurtainWall/Components/Mullion_60/Mullion_60.rb
              scrambler.exe CurtainWall/Components/Transom_60/Transom_60.rb
              scrambler.exe CurtainWall/Components/Mullion_80/Mullion_80.rb
              scrambler.exe CurtainWall/Components/Transom_80/Transom_80.rb
              This is in a loadprog.rb to call all rbs files.
              module CurtainWall
              this_dir=File.dirname(__FILE__)
              PATH=this_dir
              entries=Dir.entries(this_dir)
              ext=".rbs"
              Sketchup.load(File.join(this_dir,"CurtainWall_FStick.rbs"))
              Sketchup.load(File.join(this_dir,"CurtainWall_FUnitized.rbs"))
              Sketchup.load(File.join(this_dir,"CurtainWall_MainProgram.rbs"))
              Sketchup.load(File.join(this_dir,"cw_archtoolbar.rbs"))
              Sketchup.load(File.join(this_dir,"cw_rubytoolbar.rbs"))
              Sketchup.load(File.join(this_dir,"cw_report.rbs"))
              Sketchup.load(File.join(this_dir,"inputbox.rbs"))
              I don't know there is a problem inside my folders , or I wrote in scramble.bat wrong ?
              • A
                AcesHigh
                Hi PingPinky. Is your curtainwall plugin available to download somewhere?
                • pingpinkP
                  pingpink
                  Hello AcesHigh
                  Thank you so much for your interest !! It's a surprise that many people watched my videos. Actually , I did YouTube for a good memory , and applying for a job. Now, I'm preparing documentation for this time ,and looking for some experts to lead me here because I'm not a programmer. I hope there's a possibility to distribute soon.
                  • A
                    AcesHigh
                    thanks for the answer Pingpink.
                    somebody opened a thread about your Plugin in the Plugins sections of Sketchucation just the other day. Can you please post more info there?
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58694%26amp;p=534451#p534229
