    Puts inconsistency & machine epsilon management
    20 Posts 6 Posters 1.9k Views 6 Watching
      abakobo
      hi and thanks for all the good things you do here and that helped me a lot already!
      i have a problem with debugging a variable. when i use puts i get inconsistent values
      the following code:
      puts nb_temp=(delta*1.0/step*1.0)-(rest*1.0) puts nb_i=nb_march_temp.to_i
      prints to the console:
      4.0
      3
      i multiplied all numbers with 1.0 because it saved me several times. But this time in order to get my models correctly drawn i have to add:
      puts nb_temp=0.000000000000001+(delta*1.0/step*1.0)-(rest*1.0)
      What is ugly code to me. This code will print:
      4.0
      4
      if i add 0.00000000000001 ( so 10^-14 instead of 10^-15) it puts:
      4.00000000000001
      4
      i suppose it's a "machine epsilon" problem... http://en.wikipedia.org/wiki/Machine_epsilon
      how do you people usualy manage that kind of ".to_i" problem when operated after a division? and how can i "puts" the real float that's in memory and not a rounded one?
      thx
      ako
        Aerilius
        That's possible.
        Can you give a reduced example that includes the values of delta_t4, lstep, reste, and with readable variables like a, b, c.
        Also to_i truncates (rounds towards 0), and does not round to the nearer full number.
        puts turns the input into a string, so it is a good idea to test with to_s (or inspect) to exclude the case that the problem is in the numeric to string conversion.
          abakobo
          @aerilius said:
          That's possible.
          here is an ouput console with readable var names:
          a
          60.7869946176981
          b
          12.7368848825351
          c
          0.772516606556568
          result of (a/b)-c (auto string conversion)
          4.0
          result.to_s
          4.0
          result.to_i
          3
          if i make the calculation (a/b)-c using the values shown on the console with a "simple" calculator i get 4.000000000000003.
          thx
          ako
            Aerilius
            I cannot reproduce this in SketchUp 7.1 (Ruby 1.8.0) to SketchUp 2013 (1.8.6) and Ruby 2.0.0. But I remember I once had an example that gave 0.999… or 1.0 depending on the order of operants. I can't get it to work again on my 64bit processor (maybe it gives a different result on a 32bit).
            Did you select these numbers to invoke this problem for testing, or does this really occur in practice in your plugin? If so, wouldn't it be better to use Math.round instead of truncating with to_i?
            As for workarounds, precision is usually not a problem I need to care about, especially since SketchUp has its own tolerance where unprecise floats still fit in. If you really deal with big numbers or need highest precision, you could use BigNum or Rational.
            Otherwise it often helps to rearrange your calculation to avoid adding big and small numbers (or using offsets).
              Aerilius
              What are you trying to do? If a "split" gives a value near an integer (or a difference near zero), then it is usually not relevant for SketchUp geometry. You can't create edges of such short lengths. What are you trying to split?
                abakobo
                It happens in the plugin. The a,b,c values you see are values calculated in the plugin 100+ code lines from last inputbox.
                The Math.round is not an option as i need to know how much is left from splits and some times the split is near the edge of the step so it gives a value near to an integer (my problem) but is actually not an integer. I'll check with Rational as 64+bit numbers still have a machine epsilon anyway.
                thx
                PS: i had two questions in the first post:
                  abakobo
                  it's in a part of the code where sketchup visible geomtery is not used. it's pure applied analytical geometry (no edges or faces exists at that time, eveything is vector and points and lenght(but not edge.length !)). it evaluates how many steps of lenght "l" are in a segment of lenght "L" and that evaluation is an integer. if for example 4*"l" is 10^-15 to "L" i must have 4 steps as a result. if 4*"l" is 10^-15 past "L" the result should be 3. It is not probable at all that - x is an integer and x"l"=="L"* - and if it is the case the result should be 4 in my example. A wront number of evaluated steps will result in buggsy result.
                  sorry for my english..
                  thx
                    Aerilius
                    Anything in the range of 10^-15 is like an atom core on your finger (and the atom core is 1/10000 of the whole atom). In SketchUp models, this is usually not something we want to consider.
                    If you calculate using "virtual geometry" (from the Geom modue like Point3d), the SketchUp tolerance applies as well, like for visible geometric entities. The idea of SketchUp's tolerance is to compensate for rounding errors, because when you calculate a length one way and compare it to a theoretically same length that is calculated in another way, you want them to be equal. It is so that we developers don't need to think about it.
                    Try:
                    Geom::Vector3d.new(1,1,0) == Geom::Vector3d.new(0.999999,1.000001,0)
                    If a segments fits 3.999999 steps into a length, we can see it as the same as if it fits 4 times.
                    This is because SketchUp introduced a "Length" class, and only this has the tolerance. Integers and Floats don't have SketchUp's tolerance, but Ruby's precision with (machine epsilon).
                    All numbers that you obtain from geometry are already of the length class. All numbers that you obtain from floats automatically turn into Length when add/multiply/calculate them with lengths. Check that your numbers are of the Length class:
                    ` a = vector.length
                    a.class
                    Length
                    b = vector.x
                    b.class
                    Length`
                      abakobo
                      Great!
                      i know understand! i'll need to redefine my points and vectors with arrays of double floats if i want to reach machine epsilon accuracy!or use sketchup's ones but with sketchup precision.
                      What i still don't understand is why it wouldn't round when calling .to_i (so may be getting the difference with math.round will be solution to keep working with the Geom module).
                      thx a lot for the time you spend on my problem Aerilius!
                      ako
                        Trogluddite
                        To answer this final part of your original question...
                        The only utterly reliable way to do this is to print the value in binary!
                        Each number base has values that it can exactly represent, and those that it can't. We're all familiar with this in base ten, for example...
                        1.0 / 3.0 = 0.3333333...etc...
                        There is simply no exact representation of 1/3 no matter how many decimal places you use.
                        The same is true of base 2 (binary) - for example, a float cannot exactly represent the decimal value 0.1. The fraction 1/10 is infinitely recurring in binary...
                        0b0001 / 0b0110 = 0b0.0001100110011001100...etc...
                        In effect, there is no such number available to a float, regardless of the number of bits - and it has to make to with the nearest approximation.
                        Therefore, any time you change the number base, there will be a rounding error unless BOTH number bases can exactly represent the value. It's important to realise that this is a fundamental property of the way that numbers are represented - greater precision yields closer approximations, but will never solve the problem entirely.
                        So in your example case, where apparently 4.0.to_i == 3, what may be happening is that the 'true' binary value is ever so slightly less than 4.0, but is a value with no exact decimal representation. The nearest 'non-recurring' decimal just happens to be the integer 4 - so this is what 'puts' displays.
                        This kind of thing happens all the time, it's just that the 'integer/not-integer' case tends to make the problem more visible.
                        (NB - this is also the reason that Ruby has the Rational class of number; so that fractions with recurring/irrational decimals can be precisely represented).
                        Until we become a race of technology enhanced cyborgs that can all natively do maths in binary, this problem is always going to come up when we use float values anywhere in a user interface - the very act of displaying the value can change the value being displayed!
                        • Dan RathbunD Offline
                          Dan Rathbun
                          Will using Kernel.sprintf() help ?
                          n = 4.000000000000003 %(#004000)[4.000000000000003] n.class %(#004000)[Float] sprintf( "%.15f", n ) %(#004000)[4.000000000000003]
                          I'm not here much anymore.
                            Trogluddite
                            The 'sprintf' method used may or may not be more precise than the standard 'to_s' method, I'm not sure - but it will still never completely circumvent the problem of decimal values that binary cannot represent.
                            For example, your value '4.000...003' is just a String as far as the Ruby parser is concerned, and it get converted to binary to make a Float. When you print it, it converts back to decimal. At no point can you know whether the Float is really holding that exact number, or whether it's just that the conversion routines are exactly reversible.
                            You can't even do a simple test whether the stored value is precise or not - Ruby would always tell you that it is, because you can only compare with another Float that has also been ultimately converted from a decimal string.
                            Whether or not to round or format depends a lot on what you want to use the number for. For end users, 'decimalised' values are much more intuitive to deal with, and they are the 'norm' - but for a developer trying to locate rounding errors, this can be very deceptive.
                            Rounding the Float value itself won't always help either - the Float#round method rounds to a fixed number of decimal places - but since even 0.1 can't be exactly represented in binary, you will often still end up with an approximation.
                            I have seen some debuggers/editors that do have a setting to always print the actual binary number that is ultimately held in memory - as there is a fixed number of bits in a Float, and 2 is a factor of 10, it IS always POSSIBLE to translate the exact binary value to decimal within a bounded number of digits. When I've used these, it has been quite shocking to see what the CPU does with the values that we type in!
                            Very few applications do this because it's counter-intuitive to type in a value and then be told its something different on the display. Scientific and financial applications often use deviously complex routines for what seem like simple calculations so that they can emulate the maths being done in an 'all decimal' number space, to prevent this kind of issue.
                            Although often misunderstood and complained about, I have to say that I think the handling of rounding errors by the SU API is very well done - I think there would be many more threads like this from frustrated developers if we had to manage 'epsilon' for ourselves!
                              Trogluddite
                              In case it might be useful to anyone experiencing similar issues with numeric precision, I've tarted up a little module that I've used for a long time to peek inside number values.
                              IEEE754.rb
                              There are methods to take any Float, Integer or numeric String (including Hex/Binary), trim precision to either 32 or 64 bits, and then show.
                              • The Float value represented by those 32/64 bits.
                              • Signed and unsigned integer represented by the same bit pattern.
                              • Raw bytes that make up the value in hex and binary.
                              • Breakdown of the IEEE754 construction of the float (IEEE754 is the international standard for such things - the Wikipedia entry is a good start for understanding how Floats are built.).
                              • Shows infinities, NaNs and denormal values.
                              I designed it with another API in mind, where Ruby is interfacing to external code that can only handle 32bit floats - but it's turned out to be quite a useful tool whenever rounding errors, infinities, 'Not a Number' etc. are causing woe - and also when interfacing to external DLLs to check that all that horrible String packing/unpacking is working as expected.
                              Probably not so useful for the OP's problems, as for 64bit double-precision floats (Ruby standard), decimal values cannot be displayed any more accurately than usual (though it may hint at the case where the binary has an infinitely repeating fraction)
                              No restrictions on use, distribution etc. - nor is there any kind of warranty (caveat emptor!!)
                                archidave
                                I have come across a problem which seems to be related to this issue.
                                > r1 = (20.0/1000)/0.8
                                0.025
                                > r1.class
                                Float
                                > "%.2f" % r1
                                0.02
                                => INCORRECT
                                However;
                                > "%.2f" % (20.0/(0.8*1000))
                                0.03
                                => CORRECT
                                > r2 = 0.025
                                0.025
                                > r2.class
                                Float
                                > "%.2f" % r2
                                0.03
                                => CORRECT
                                > "%.2f" % 0.025
                                0.03
                                => CORRECT
                                Also:
                                > r1 <=> 0.025
                                -1
                                => INCORRECT
                                > r2 <=> 0.025
                                => CORRECT
                                > r1 <=> r2
                                -1
                                => INCORRECT
                                So it is clearly something to do with how the number is stored in binary and the order of operators can affect the result as alluded to above in this thread.
                                Any ideas on how to manage this? - it seems quite a fundamental flaw if this comes up when making calculations at a pretty basic level of precision. It doesn't seem practical to re-order potential calculations to push the precision one way or another because the values of variables may not be known in advance.
                                  Trogluddite
                                  "Fundamental" - that is the key word. The problem is just inherent in any numeric system with a finite amount of precision. Without hugely complex (i.e. slow) assessment of the "rules of mathematics", programs will always work this way. When we do maths using our brains as the computer, we implicitly use all those extra rules without even realising we are doing it - so the quirks of floating point maths come as a nasty surprise to most programmers at some point in their career.
                                  If we add the width of an atom to the diameter of the solar system, logic tells us that we must have made the original number larger - but to a CPU, all it sees is that the pattern of bits in a register probably didn't get changed, and that makes the end result "equal" to the start value despite what the semantics of the equation tell us.
                                  This can be overcome with special processing that does interpret the "meaning" of the maths. For example, if you were to do the same maths as your example using Ruby's "Rational" class of numbers, you would get exactly the expected answer - but the cost in extra CPU load is huge and would likely outweigh the advantages in most cases.
                                  I do a fair bit of Audio DSP programming, where equations are often used within feedback loops at high sample rates, and it is incredible the difference that a simple swap of instructions can make - beautiful smooth filtering one way, blown speakers/eardrums another! How do I know which to use? - if I'm lucky, Google will find me the most stable algorithm, otherwise it's mostly just good old trial and error!
                                  It's an area of computer science that fills volumes of textbooks and research papers every year - and sadly, there are very few 'shortcuts' that us mere mortals can rely on. But to make the most of the available precision, this kind of code re-factoring is indeed the most "practical" solution.
                                  There are a few 'rules of thumb', though. For example, when adding and subtracting, the result is usually most reliable when the two values are similar in magnitude - but, of course, some algorithms just don't have an easy way to arrange that!
                                  • tt_suT Offline
                                    tt_su
                                    If you haven't come across this website already I highly recommend the read:
                                    http://floating-point-gui.de/
                                    If high precision is required you might want to look into the special classes in Ruby to handle such. You have Rational for instance.
                                      Dan Rathbun
                                      FWIW, your first example:
                                      r1 = (20.0/1000)/0.8 puts r1 %(darkgreen)[>> 0.024999999999999998]
                                      .. so, therefore:
                                      "%.2f" % r1 %(darkgreen)[>> 0.02]
                                      .. is CORRECT, not incorrect.
                                        archidave
                                        Thanks all,
                                        Thom, that link looks very useful thanks, makes me think I should dig out my A-level computer science notes too ...
                                        Dan, I still get
                                        0.025
                                        > puts r1
                                        0.025
                                        How do you output the full precision in order to understand what is going on?
                                        I don't have the Rational class in SU8 (I'm on OS X 10.6.8 so can't go any higher for the time being)
                                        FYI;
                                        RUBY_VERSION
                                        1.8.5
                                        Do I need Ruby 2.0 for that?
                                        Dave
                                        • tt_suT Offline
                                          tt_su
                                          FYI;
                                          RUBY_VERSION
                                          1.8.5
                                          Indeed. We used Ruby 1.8 with just the core lib up til and including SU2013. In SU2014 we upgraded to Ruby 2.0 and included most of the stdlib.
                                            Dan Rathbun
                                            There are some class level constant settings for the Float class.
                                            List them: Float.constants
                                            Example: Float::DIG
                                            15
