    Hide at a distance from the camera - works but slooooowwww
    4 Posts 3 Posters 324 Views 3 Watching
    • alexandre skA Offline
      alexandre sk
      Hello again.
      I was playing with the ruby and make a little plug in to hide everything away from the camera.
      Like this:
      It work perfectly! but slow like a turtle! this scene above take about 20 seconds
      Here is the script:
      model=Sketchup.active_model
      eye=model.active_view.camera.eye
      selection = Sketchup.active_model.selection
      selection.each { |entity|
      	distance=eye.distance(entity.bounds.center)
      	if distance > 20000
      		entity.hidden = true
      I think that calculate the center of all items is very hard work. Maybe you guys have a way that don't make the cpu calculate so hard. Or maybe what is taking time is to calculate the distance, then teh ideia is bad after all.
      • Dan RathbunD Offline
        Dan Rathbun
        You could also adjust the fog settings.
        I'm not here much anymore.
          alexandre sk
          well the idea is to work with large models, and don't have to manually hide objects to give more frame rate. I thinks fog don't help with less entities to display.
          • tt_suT Offline
            tt_su
            Fog generally tends to slow down the framerate.
