    Login popup
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    3 Posts 3 Posters 7.6k Views 3 Watching
      Aerilius
      In addition to the normal login field there is a javascript popup that appears to be redundant. What is its use?
      • browsers do not fill in the username/password so I would have to type it every time. The original static login field remembers the password data.
      • I have to click it away
      • unusable on mobile because it jumps offscreen when I try to scroll, zoom or give keyboard focus
      • Dan RathbunD Offline
        Dan Rathbun
        I use a bookmark (favorite) link directly to:
        http://sketchucation.com/forums/ucp.php?mode=login
        No popup.
        I'm not here much anymore.
        • G Offline
          Gábor
          The goal of this "login popup" is to inform new visitors about the membership options and to make it obvious for them that they should register as a member to be able to use all the features of SketchUcation.
          It was set in a way that it popped up only for not logged in visitors hourly. So if some not logged in user visited the site again after an hour he/she got the popup again until he registered/logged in.
          I do understand that this could be annoying to frequent user members who do use direct-links to access the site. Therefore now I changed the repetition time from an hour to 1 week. So if you do not erase your cookies now you won't see again this popup for a week.
          I'll also check what can I do to get rid of this box in case of mobile devices.
