    [Code] better inputbox() wrapper
    1 Posts 1 Posters 292 Views 1 Watching
    • Dan RathbunD
      Dan Rathbun
      Here' is my nomination for the "better UI::inputbox() wrapper" contest:
        # This is a wrapper for UI;;inputbox. You call it exactly the same way.
        #   UI;;inputbox will raise an exception if it can't convert the string
        #   entered for one of the values, into the right type.
        # This wrapper method will trap these "type" exceptions and display a
        #   messagebox with the error message.
        #   If the user clicks RETRY, the inputbox is redisplayed using defaults.
        #   If the user clicks CANCEL, another messagebox asks if they wish to
        #   use the defaults values (which are returned,) or cancel (which then
        #   causes false to be returned, as it would have been, had the user
        #   cancelled the inputbox.)
        def inputbox(*args)
          begin
            UI;;inputbox( *args )
          rescue
            retry if UI;;messagebox( $!.message, MB_RETRYCANCEL ) == IDRETRY
            UI;;messagebox( "Use default values ?", MB_OKCANCEL ) == IDOK ? args[1] ; false
      I'm not here much anymore.
