EntitiesObserver Weirdness
OK. I have repeatable steps for the Sketchup:EntitiesObserver that show some STRANGE behavior.
Use this code:
` class KW_EntitiesObserver_Weirdness < Sketchup::EntitiesObserver
def initialize(*args)
super
@m = nil
def onActiveSectionPlaneChanged(entities)
def onElementAdded(entities,entity)
def onElementModified(entities,entity)
puts "onElementModified: #{entity}"
if entity.is_a? Sketchup::Material
@m = entity
puts "material is #{@m}"
def onElementRemoved(entities,entity)
def onEraseEntities(entities)
enddef method_missing(meth,*args,&block) endend`
Materials Weirdness:
- In Sketchup, draw a few faces. Enclose them in a group
- Load the code above
- Select the group
- Do the following in the ruby console:
s = Sketchup.active_model.selection s[0].entities.add_observer KW_EntitiesObserver_Weirdness.new- Now change the material of one of the faces in the group. The observer will fire (at least) twice. In my case it sometimes fires three times - the first two times for the material. The console output should look like this:
onElementModified: #<Sketchup::Material:0x9c2328> material is #<Sketchup::Material:0x9c2328> onElementModified: #<Sketchup::Face:0xa77588> material isFor some reason, the material that was stored as @m after the first observer call has been lost. Even more strange, if you add the observer, to Sketchup.active_model.entities everything works fine. The steps for this are:
- In the ruby console:
Sketchup.active_model.entities.add_observer KW_EntitiesObserver_Weirdness.new- Now change the material of one of the faces in the group. Again, the observer fires (at least) twice. In my case it sometimes fires three times - the first two times for the material. In any case @m maintains the reference to the material:
onElementModified: #<Sketchup::Material:0x98b3c8> material is #<Sketchup::Material:0x98b3c8> onElementModified: #<Sketchup::Material:0x98ae28> material is #<Sketchup::Material:0x98ae28> onElementModified: #<Sketchup::Face:0x98b680> material is #<Sketchup::Material:0x98ae28> -
What happens if you hold a reference to your observer instance?
Hi Dan,
Holding a reference does't make any difference. The only time the reference held by @m is actually stored is when the observer is assigned to Sketchup.active_model.entities.
Also, I noticed that in cases where I have a new file, and I first add the observer to a group's entities collection, the observer does not alert onElementModified for the material. It only alerts for the face.
Thanks,
Karen
Register LoginAdvertisement
