    Move instances softly, using the mouse
    4 Posts 2 Posters 472 Views 2 Watching
    • D
      dacastror
      hi all, I'm trying to make a tool to move groups, similar to the native tool of sketchup, but so far I'm starting, I wrote the following code and I do not know why the group does not move smoothly
      #before beginning must have a selected group
      class MoveGroup
         def onMouseMove flags, x, y, view
            mod = Sketchup.active_model
            sel = mod.selection.to_a[0]
            input = view.inputpoint x,y
            p = input.position
            tr = Geom;;Transformation.translation p
            sel.move!(tr) if sel.is_a?(Sketchup;;Group)
            view.refresh
      Sketchup.active_model.select_tool MoveGroup.new
      in advance I appreciate your help (Google translator)
      • D
        driven
        hi
        it jumps about because it doesn't know where in 3d space the mouse is...
        when you lock onto an axis it's fine
        try using arrow keys as a modifier...
        john
        • D
          dacastror
          thank you very much, is what I needed to know 😄
          by the way, I wanted to look at your plugins and I did not find them, look in the pluginstore and select search by author...
          • D
            driven
            @dacastror said:
            ... I wanted to look at your plugins and I did not find them, look in the pluginstore and select search by author...
            you won't find them, there's a couple on limited beta release and a few of mac only dev tools that almost no-one else has even seen...
            I keep adding to them on the day I decide to release, then I want to test again, ect... etc...
            I PM the closest to release one if you want to comment on it...
            john
