    How to open attributes ?
    2 Posts 2 Posters 326 Views 2 Watching
    • G
      goga63
      Good day !
      On this great forum I found the code which creates a simple cube
      new_comp_def = Sketchup.active_model.definitions.add("MyCube") ;
      points = Array.new ;
      points[0] = ORIGIN ;
      points[1] = [100, 0 , 0] ;
      points[2] = [100, 100, 0] ;
      points[3] = [0 , 100, 0] ;
      newface = new_comp_def.entities.add_face(points) ;
      newface.reverse! if newface.normal.z < 0 ;
      newface.pushpull(100) ;
      trans = Geom;;Transformation.new ;
      Sketchup.active_model.active_entities.add_instance(new_comp_def, trans) ;
      But immediately after creation of the Cube section of the size attributes closed
      screen1.
      how to modify the code to section size attributes (or any other ) was opened ?
      screen2
      • Dan RathbunD
        Dan Rathbun
        Entity#get_attribute()
        Entity#set_attribute()
        The dictionary name is "dynamic_attributes"
        I'm not here much anymore.
