    Why is a box deleted / Why is a box not a manifold?
    7 Posts 2 Posters 882 Views 2 Watching
    • F Offline
      Frank Brugman
      Hi all,
      Embarrassing simple questions (I think):
      1. The code underneath gives the message "bbx1 deleted!"
        What is happening and how do I prevent it from being deleted?
      2. The code underneath gives alse the message "bbx2 is not a manifold"
        What is happening and how do I make it a manifold?
        ( I want to learn about boolean solid operations like union etc,... )
      With kind regards,
      Frank Brugman
        bbxmax   = Geom;;Point3d.new
        bbxmin   = Geom;;Point3d.new
        bbxmin.x = 1000.mm
        bbxmin.y = 0.mm
        bbxmin.z = 0.mm
        bbxmax.x = 2000.mm
        bbxmax.y = 1000.mm
        bbxmax.z = 1000.mm
        boxpts = []
        boxpts[0] = [bbxmin.x, bbxmin.y, bbxmin.z]
        boxpts[1] = [bbxmax.x, bbxmin.y, bbxmin.z]
        boxpts[2] = [bbxmax.x, bbxmax.y, bbxmin.z]
        boxpts[3] = [bbxmin.x, bbxmax.y, bbxmin.z]
        face1 = Sketchup.active_model.entities.add_face boxpts
        face1.reverse!
        face1.pushpull(bbxmax.z-bbxmin.z )
        bbx1 = Sketchup.active_model.entities.add_group
        bbx1.entities.add_group face1.all_connected
        bbxmin.x = 2000.mm
        bbxmin.y = 0.mm
        bbxmin.z = 0.mm
        bbxmax.x = 3000.mm
        bbxmax.y = 1000.mm
        bbxmax.z = 1000.mm
        boxpts = []
        face2 = Sketchup.active_model.entities.add_face boxpts
        face2.reverse!
        face2.pushpull(bbxmax.z-bbxmin.z )
        bbx2 = Sketchup.active_model.entities.add_group
        bbx2.entities.add_group face2.all_connected
        if ( bbx1.deleted? )
          UI.messagebox("bbx1 deleted!")
        if ( not bbx2.manifold? )
          UI.messagebox("bbx2 is not a manifold")
      • tt_suT Offline
        tt_su
        Looking at it...
        Sidenote: when using the Ruby API you create the group first then add the entities to the group. Inverse of what you do via the UI.
        • tt_suT Offline
          tt_su
          Another side note:
          Instead of this:
            bbxmin.x = 1000.mm
            bbxmin.y = 0.mm
            bbxmin.z = 0.mm
          it's much simpler to write:
            bbxmin   = Geom;;Point3d.new(1000.mm, 0.mm, 0.mm)
          • tt_suT Offline
            tt_su
            Right, so the deleted? thing happen because you make the face first, then try to move it into another group - a nested group event.
            Rearranging so you create your groups first, then add the faces fixes that.
            The manifold? test fails because bbx2 contains another group inside it. That group however is a manifold. Maybe you didn't intend to create two levels of nested groups?
              bbxmin.x = 1000.mm
              bbxmin.y = 0.mm
              bbxmin.z = 0.mm
              bbxmax.x = 2000.mm
              bbxmax.y = 1000.mm
              bbxmax.z = 1000.mm
              boxpts = []
              g1 = bbx1.entities.add_group
              face1 = g1.entities.add_face boxpts
              face1.reverse!
              bbxmin.x = 2000.mm
              bbxmin.y = 0.mm
              bbxmin.z = 0.mm
              bbxmax.x = 3000.mm
              bbxmax.y = 1000.mm
              bbxmax.z = 1000.mm
              boxpts = []
              g2 = bbx2.entities.add_group
              face2 = g2.entities.add_face boxpts
              face2.reverse!
            • F Offline
              Frank Brugman
              Hi Thom,
              Thank you for your quick respons.
              I indeed did not want to create a two level nested group.
              Is it easy for you to tell me how I got rid of one of the two levels?
              With kind regards, Frank
              • F Offline
                Frank Brugman
                Hi Thom,
                Thank you for your quick respons. It works!
                With exploding the groups I got rid of the two levels.
                With kind regards,
                Frank
                Enjoy spring!
                • tt_suT Offline
                  tt_su
                  There is no need to explode - just don't create two groups.
                  Change this:
                    face1.reverse!
                  to
                    face1 = bbx1.entities.add_face boxpts
                    face1.reverse!
                  If you read your code carefully you will see that you call add_group twice, once in the root entities element and once in the first group you created.
