    Document.getElementById ?
    8 Posts 3 Posters 660 Views 3 Watching
      driven
      on a mac, both of these work...
      is that the same on other PC variants...
      d.execute_script %Q(document.getElementById('trans_L8').value='Translate';)
      d.execute_script %Q(trans_L8.value='Translate';)
      john
        Aerilius
        Well, it's something basic one expects from all browsers to work. Not a question of operating system.
        But I use document.getElementById a lot (or frameworks using it) and it works, in IE, even the old IE6.
        Whether you can use .value= depends on what type of element you access ( HTMLInputElement ?).
          driven
          the question is about the shorthand access inside a Webdialog, so WebKit v IE...
          I find it cleaner without document string element...
          and when generating dynamically the files smaller, so should be faster?
          so, to rephrase, can IE handle the shorthand for any attribute, value/name/title etc...
          john
          • G Offline
            Gábor
            My quick test with Sketchup v2014, IE 11 shows that both forms work. Have no information about other versions.
              driven
              cheers Gábor,
              I have a lot of them and the shorter the better...
              john
              • G Offline
                Gábor
                @driven said:
                cheers Gábor,
                john
                I've entered the following lines in to the ruby console for the test:
                ` dlg = UI::WebDialog.new("TEST", true,"TEST", 739, 641, 150, 150, true);
                #UI::WebDialog:0xb4e49d8
                dlg.set_html('<html><head></head><body><div id="trans_L8"></div></body></html>')
                nil
                dlg.show
                true
                dlg.execute_script %Q(document.getElementById('trans_L8').innerHTML='Long';)
                true
                dlg.execute_script %Q(trans_L8.innerHTML='Short';)
                true`
                If somebody wants to try it with other version combinations...
                  driven
                  or select all...
                  dlg = UI;;WebDialog.new("TEST", true,"TEST", 739, 641, 150, 150, true);
                  dlg.show
                  on mac you need to split it twice... but I know it works on mac...lol
                  john
                  • G Offline
                    Gábor
                    Thank you for the formatting. The splitted version works on PC, IE11, SU 2014.
