    Count instances correctly
    3 Posts 2 Posters 412 Views 2 Watching
      dacastror
      ins
      hi all, I would like to know how to count the number of instances of a definition, the "Entity Info" window appears correctly but definition.count_instances do not, is there anything in the API or somewhere to get this information? attached skp file with which I am doing tests
      instances.skp
      thank you very much in advance for the help
      (google translator)
      • Dan RathbunD Offline
        Dan Rathbun
        See how I did it in this plugin I wrote for Ash Scott:
        [Plugin] Multiple Component Edit Warning
        I'm not here much anymore.
          dacastror
          Thanks Dan, this can give me a hint, I'm testing with the definition given there, but in my testing model (instances.skp) gives me a wrong number of instances, sometimes less or sometimes more, I do not know if I'm misapplying the definition count_instances ()
          # you must have a selected instance
          def count_instances()
            num = 0
            if @editpath.size == 1
              i = @editpath.last
            else
              revpath = @editpath.reverse
              i = revpath.shift
            if i.is_a?(Sketchup;;ComponentInstance)
              num = i.definition.instances.size
            elsif i.is_a?(Sketchup;;Group)
              num = i.entities.parent.instances.size
            if @editpath.size > 1
              revpath.each {|i|
                  num = num * i.definition.instances.size
                  num = num * i.entities.parent.instances.size
            return num
          mod = Sketchup.active_model
          sel = mod.selection
          ruta = mod.active_path
          (ruta) ? (ruta[ruta.size] = sel[0]) ; (ruta = []; ruta[0] = sel[0])
          @editpath = ruta
          count_instances()
