    Storing Geometry
    8 Posts 3 Posters 660 Views 3 Watching
    • G Offline
      Garry K
      Has anyone stored small amounts of sketchup data to disk files (not skp).
      I would like to add to door maker the notion of user definable door pulls (handles) and then store these items into a folder. The name of the file will become the entry in the drop down list.
      Alternatively is there a way to store a handle in a skp file like the warehouse and then through code automatically fetch it and insert it into the drawing.
      • tt_suT Offline
        tt_su
        Why not save the component to disk as SKP? Then load it as a component again?
        Making your own file format - or even using another existing format - seems like extra work for no gain.
        • G Offline
          Garry K
          I've got this working now however there is one thing I'm wondering about.
          If I add 3 doors that use the same door handle, each within their own commit.
          I undo once and the last door disappears. I undo a second time and the same thing happens.
          So far so good!.
          But then I need to undo several times to remove the first door. It appears that loading the handle component within the start_operation / commit sequence breaks the sequence but just for the door where we go to disk. As long as the definition is already in the model then it behaves as expected.
          • Dan RathbunD Offline
            Dan Rathbun
            YES, in answer to the skp question, as to both local component library, and 3DW skp file.
            DefintionList#load()
            DefintionList#load_from_url()
            A component saved as a skp, can have options saved into the "dynamic_attributes" attribute dictionary.
            Have you played around with any of the components in the Sample library ?
            EDIT: corrected name of dictionary
            I'm not here much anymore.
            • G Offline
              Garry K
              It seems wrong but it appears to work better if I load the component definition outside of the start_operation / commit operation. Anyway - I will continue doing it this way until someone comes up with another idea to try.
                Dan Rathbun
                Well I was going to suggest this anyway, but with the addition that the definition load gets it's own operation named "Load Component: 'Handle'". (But then SketchUp actually creates an operation for it anyway with the generic name "Load Component".)
                • tt_suT Offline
                  tt_su
                  What version of SketchUp are you testing on? In SU2014 we fixed this:
                  Fixed DefinitionList.load and load_from_url which did not start Ruby operations properly.
                  They completely mess up the undo stack unfortunately on older SketchUp versions.
                  http://www.sketchup.com/intl/en/developer/docs/releases
                  • G Offline
                    Garry K
                    Thankyou - this will be a good read!
                    I currently test on SU 7, SU 8, SU 2013 and SU 2014. The work around is easy enough.
