    Question on =begin and =end
    3 Posts 2 Posters 403 Views 2 Watching
      ladyquestio
      I ran across a ruby that has these used in it.
      am I correct in understanding it is the same as using the rem ## except it remarks out anything between them?
      like this
      =begin
      none of this would be processed
      regardless of what is inside
      the processing ruby
      =end
      Coding continues...
        Jim
        Correct, Ruby does not process the lines between. They are typically used for block comments. And if used, the equal sign must be the first character in the line (no whitespace.)
          ladyquestio
          Thank you for the answer.
          that helps me understand a bit more of ruby scripting
