    [Code] SU8 Cleanup User Toolbar entries
    1 Posts 1 Posters 245 Views 1 Watching
    • Dan RathbunD
      Dan Rathbun
      NO WARRANTY : USE AT YOUR OWN RISK
      Speeds up SketchUp 8 start times when the toolbar registry entries become bloated.
      I updated the command file a bit (from Thomas' 2 liner):
      (1) saves current WD and switches to the User Home dir.
      (2) first deletes an old file if it exists (because the REG QUERY appends to the file.)
      (3) Echos the number of lines containing keys to be deleted.
      (4) Accepts a "view" argument that will open the generated key file in the system's default text application, at the end of processing.
      (5) Switches back to the previous directory.
      @echo off
      set olddir= %CD%
      cd %USERPROFILE%
      if exist su_reg_keys.txt del su_reg_keys.txt
      reg query "HKCU\Software\Google\SketchUp8" | find "ToolbarsUser" >> su_reg_keys.txt
      echo .
      echo SketchUp Toolbar Registry entries to be deleted;
      find /C /I "HKEY" su_reg_keys.txt
      echo .
      for /f %%k in (su_reg_keys.txt) do (
          reg delete %%k /f
      REM   Open file in default text application
      REM   if "view" param is passed;
      if %1.==view. su_reg_keys.txt
      if %1.==VIEW. su_reg_keys.txt
      cd %olddir%
      set olddir=
      Copied from another forum, hidden on page 2 of a topic thread.
      I'm not here much anymore.
