    Modern Glass Display
    8 Posts 5 Posters 1.7k Views 5 Watching
    • V
      Vigy
      Hi Guys;
      I'm visiting SketchUcation daily now, great site, wonderful community. Just wanted to share some of my work, well it’s not the traditional wood work you see here 😉 but more of a modern style, Hope you like it 😐
      12"H Display: 3/8” thick glass UV bonded, with pull out deck and glass front.
      Base: LP material and post Laminate or paint job on MDF.
      • V
        Vigy
        After a Render.
        • V
          Vigy
          Added a “LED light stand” on deck, draw it dynamic so I can easily adjusted for light pointing position.
          • M
            mwm5053
            nice work on both models and renders
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
            • V
              Vigy
              Thanks Walt!
              • Y
                yukon
                Very cool. I would have never thought to have the whole deck and front slide out for ease of use. I guess with the heavy-duty slides we have available now these days this is a very elegant solution.
                • wilsonbuilt78W
                  wilsonbuilt78
                  Excellent design solution, do a fair amount of this type of work myself and intend using your solution, great work on the modelling and rendering BTW. Thanks for sharing
                  Heres a glass cabinet I manufactured from lasercut mild steel with the model I used to have it cut. Hope you likeupper drinks shop.skp
                  • olisheaO
                    olishea
                    nice work
                    oli
