    Name of the top parent
    7 Posts 3 Posters 625 Views 3 Watching
    • G
      goga63
      Hi !
      There is a component with what structure:
      Model
      Top parent
      parent
      parent
      child
      Whether there is a method to learn for "child" a name "Top parent"?
      On an example "Generate Report" 1 column "PATH" shows a way to "child"
      And if to take a name of a component 2 levels (a column "LEVEL") we learn a name "Top parent". If I have correctly understood that it is necessary to connect still a file dcclass_v1.rbs.
      But what is necessary a code for reception of a name of a component 2 levels ("Top parent")?
      • Dan RathbunD
        Dan Rathbun
        IF you (or the user,) is in edit mode of Component#2, then:
        Sketchup::active_model.active_path
        will return an array of the nesting path.
        Otherwise inst.parent() returns the definition who's entities collection contains this instance.
        But, if the parent definition has multiple instances in the model,... which one of those instances is the one wrapping the lower instance ?
        There may not be a way to tell ??
        I'm not here much anymore.
        • G
          goga63
          How Generate Report obtains this data without being in a mode of editing of a component?
          • tt_suT
            tt_su
            Generate Report traverses the whole model from model.entities and traverse over everything in the model.
            However, given an arbitrary component instance it's not possible to always get an exact hierarchy path to it's parents because it might be contained within multiple other instances - in which case you have ambiguity to what the correct result would be.
            • G
              goga63
              ok. I have understood it.
              On image1 the way for the chosen component 5 is shown.
              On image 2 the component 3 is allocated,
              By means of a code I obtain the data for a component 1.
              any_attribute = entity.get_attribute ("dynamic_attributes", "any_attribute", 0).to_s
              can I somehow temporarily make the component 1-active , will receive path, and revert to a previous state?
              • tt_suT
                tt_su
                There is no way to change the active context in the Ruby API. You can only close it.
                But it doesn't change the problem. If you have one component instance, there is is no way to knowing where it belong to.
                Say we have a component "A". There is an instance of it in component "B". Say we have two instances of component "B": if we have a references to the instance of "A" it is impossible to tell which of the instances it belong to - because the very same instance of "A" exist at the same time in both instances of "B". Or to be more specific, An instance of "A" exist in the definition of "B". We can only trace the parent of "A" to the definition of "B" - not the instances.
                Model
                  ╠═B
                  ║ ╚A
                  ╚═B
                    ╚A
                You need context do determine where it belong to.
                What is it you are making? What is the goal you are trying to achieve?
                • G
                  goga63
                  @tt_su said:
                  ...What is it you are making? What is the goal you are trying to achieve?
                  I wanna make it
