    How to create the pulldown menu for DC
    6 Posts 2 Posters 472 Views 2 Watching
    • G Offline
      goga63
      Hi !
      I learn to write scripts for Sketchup, вut has rested against a wall...
      I can set attributes of components this code:
      entity.set_attribute 'dynamic_attributes','price', '0'
      entity.set_attribute 'dynamic_attributes','_price_label', 'price'
      entity.set_attribute 'dynamic_attributes','_price_formlabel', 'Price'
      entity.set_attribute 'dynamic_attributes','_price_units', 'STRING' entity.set_attribute 'dynamic_attributes','_price_access', 'TEXTBOX'
      It works!
      But I could never understand how to write code using meta attributes to create the pulldown menu for DC ...
      Show me a code fragment which it does.
      Thanks !
        Jim
        You know where the DC Attributes are stored, so now you can inspect the "dynamic_attributes" Dictionary to see how to recreate any DC you find.
        Here is a basic example of a dropdown list with 3 options:
        http://i.imgur.com/mKVm8qT.png
        • G Offline
          goga63
          Code:
          sang = Sketchup.active_model.entities[0]
              sang_def = sang.definition
              sang_def.set_attribute 'dynamic_attributes','test', 'yes'
              sang_def.set_attribute 'dynamic_attributes','_test_access', 'LIST'
              sang_def.set_attribute 'dynamic_attributes','_test_formlabel', 'My test'
              sang_def.set_attribute 'dynamic_attributes','_test_label', 'my_test'
              sang_def.set_attribute 'dynamic_attributes','_test_options ','&yes=yes&no=no'
              sang_def.set_attribute 'dynamic_attributes','_test_units', 'STRING'
          Result on the image
          What do I do not so?
          • G Offline
            goga63
            I have found a problem!
            It was necessary to use a symbol " instead of ' .
              Jim
              You have an extra space in this line:
              ang_def.set_attribute 'dynamic_attributes','_test_options[highlight=#ff0000:2ph6o4z3]_[/highlight:2ph6o4z3]','&yes=yes&no=no'
              • G Offline
                goga63
                ang_def.set_attribute 'dynamic_attributes','_test_options[highlight=#ff0000:169f3gnp]_[/highlight:169f3gnp]','&yes=yes&no=no'
                Yes, thanks!
                All has earned.
