    Calculate the needed width of a WebDialog
    10 Posts 3 Posters 689 Views 3 Watching
    • onidarbeO Offline
      onidarbe
      I like to calculate the width I should make a WebDialog to hold a certain sentence. Now it seems to be 8 times the amount of characters +20 for the border. But is this always the same on every computer? windows+mac?
      What if I add some html formatting? So I was maybe thinking on using a hmtl DIV with auto-fit, but how do I read that back, calculate and resize the WebDialog?
      Can I even lose the title-bar and/or the borders of a WebDialog?
      thanks
      myVar="Hello World" popup = UI::WebDialog.new("", false, "WebDialog", 20+8*myVar.length, 100, 50, 150, false) popup.set_html( myVar ) popup.show UI::start_timer(0.5, false) { popup.close }
      • Dan RathbunD Offline
        Dan Rathbun
        If YOU do not set the font properties, then they will differ on each platform, and may also differ on single platform from browser version to version.
        Read an online tutorial for CSS and write your html with a Ruby "HERE Document" that specifies an inline stylesheet.
        See the EditFlag plugin I wrote for AshScott. It has an inline stylesheet.
        CSS REF:
        • Learning CSS
        • CSS Wikibook
        • [MSDN: Cascading Style Sheets](http://msdn.microsoft.com/en-us/library/ms531209(v)
        Inline style sheets with <STYLE> tag: http://msdn.microsoft.com/en-us/library/ms535898(v=vs.85).aspx
        Multi-line strings in Ruby (aka Here Documents):
        http://phrogz.net/ProgrammingRuby/language.html#strings
        πŸ’­
        # This is Ruby;
        myVar="Hello World"
        # This is a "HERE Document". The identifier can
        #   be any word, not just "HERE"
        html= <<HERE
          <html>
            <head>
              <!-- inside the style tags is a CSS stylesheet -->
              <style>
                DIV.certain {
                  font-family ; sans-serif;
                  font-weight ; bold;
                  font-size   ; medium;
              </style>
            <head>
            <body>
              <div class="certain">#{myvar}</div>
            </body>
          </html>
        HERE
        popup.set_html( html )
        RUBY_PLATFORM =~ /darwin/i ? popup.show_modal ; popup.show
        πŸ’­
        I'm not here much anymore.
        • tt_suT Offline
          tt_su
          Then there is also the matter of monitor DPI and font scaling.
          And the windows borders isn't the same between platforms - and they can vary from theme to theme. Some people use applications like WindowBlinds which can greatly change with width of the border.
          Calculations is going to be very fragile.
          What are you trying to achieve?
          • onidarbeO Offline
            onidarbe
            Thanks.
            I'm trying to make a method that pop-ups a given message for a short time. I like it to have a auto width and height. Maybe I could use a DIV that automatically changes his size of what's inside. But how can I read the displayed size of that DIV back into Ruby?
            msg = "
            <html>
              <div id='msg' style='border;1px solid black;  float;left'>
                All plugins reloaded from;<br>
                #{folder}
              </div>
              <script type='text/javascript'>
                width=document.getElementById('msg').offsetWidth;
              </script>
            </html>"
            popup = UI;;WebDialog.new("", false, "WebDialog", 800, 200, 50, 150, false)
            popup.set_html(msg)
            popup.show
            UI;;start_timer(2, false) { popup.close }
            So how do I get that Javascipt variable: width back into Ruby?
            • tt_suT Offline
              tt_su
              Use a callback to make a call from JS to Ruby:
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/webdialog.php#add_action_callback
              Can't remember if I've already shared this link with you, but here's some notes about WebDialogs: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki
                Dan Rathbun
                But you never use msg.length to adjust the width of the dialog ?
                • onidarbeO Offline
                  onidarbe
                  Hey Dan, Nice that I get a question from a guru 😎
                  So no, I didn't use msg.length. I let a DIV auto-resize around the message, then I read the width of the DIV and reset the window-size. This way I know exactly what size the text takes, never mind what system. At least that's what I'm thinking. Someone needs to test it on a Mac...
                  There is however still the size of the window-frame that I can't predict, so I added 30 & 60 to width & height. It would be nice if I find a solution to have my own narrow border without the header, if anyone has an idea, let me now...
                  You can see what is happening with the DIV if you add border:1px solid black; into the style, as this will show a frame around the message where I get the size from. To be able to resize the popup window, you need to change the last falseto trueas this stands for resizable!
                  Now I like to make my own advanced but simple UI.messagebox with input, checkboxes and radio's.
                  PS: I've added some remarks to the code above.
                    Dan Rathbun
                    That is is a great idea!
                    πŸ‘
                    • tt_suT Offline
                      tt_su
                      I've used similar to set the size of a webdialog specifying the client area: https://github.com/thomthom/SKUI/blob/master/src/SKUI/window.rb#L98
                      • onidarbeO Offline
                        onidarbe
                        Thanks!
                        I found the solution...
                        [update 2013-01-23]
                        def popup(msg="", timeOut=0, posX=20, posY=70) # 2013-01-23 onidarbe () gmail
                        # Popup a message (including html-tags & \r) with a timout and auto-resize the window
                        # A click on the popup-window will disable timeOut and has to be closed manually
                          # To see how it's working, add  border;1px solid black;  in the <div style='...'>
                          htmlCode = %{
                            <html onclick='clicked();' >
                              <div id='div' style='float;left; white-space;nowrap;' >
                                #{msg.gsub(/\r/,"<br>\n")}
                              </div>
                                width=document.getElementById('div').offsetWidth;
                                height=document.getElementById('div').offsetHeight;
                                document.write("<input type='hidden' id='width' value='" + width + "'/>");
                                document.write("<input type='hidden' id='height' value='" + height + "'/>");
                                function clicked() { location = 'skp;clicked' };
                                document.body.scroll = "auto";
                              </script>
                            </html>
                          win = UI;;WebDialog.new( "" )
                          # NOTE; Variables made up on multiple lines have only a \n at the end of each line!
                          #       "View source" with Windows Notepad needs to have \r\n
                          win.set_html( htmlCode.gsub(/\r\n|\n\r|\n|\r/,"\r\n") )
                          # Although WebDialog without pref_key doesn't keep size or location, set_size does!
                          # Thereby start with a smaller window instead of a larger previous version
                          win.set_size( 130, 30 )
                          win.set_position( posX, posY )
                          win.show
                          UI;;start_timer( 0, false ) {
                            win.set_size( win.get_element_value("width").to_f+60,
                                          [800, win.get_element_value("height").to_f+80].min )
                          if timeOut != 0
                            timerID = UI;;start_timer( timeOut, false ) { win.close }
                            win.add_action_callback( "clicked" ) { UI.stop_timer( timerID ) }
                        pluginPath = Sketchup.find_support_file( "Plugins" )
                        Dir.chdir( pluginPath )
                        rbFiles = Dir[ "*.rb" ]
                        popup( "<B>All plugins;</B>\r#{pluginPath }\r\r#{rbFiles.join("\r")}", 2 )
