    Help! When an Object get touched by a Shadow (sun shade)
    4 Posts 2 Posters 691 Views 2 Watching
    • I Offline
      immcamp410
      Hi, I'm newbie here......can anyone help me to solve this algorithm that can applied in sketchup:
      Ifa Shadow touching a SolarPanel :
      Then, messagebox : Forbidden solar panel position!
      Else
      doing solar panels energy calculation
      note : the Shadow (from sun shade) in range Januari-Desember , 7am-5pm
      i'm stuck in the way shadow touch solar panel, can anyone explain?
      I attached the screenshot:
      the solar panel get touched by the tower's shadow in May
      • JuantxoJ Offline
        Juantxo
        You can use Model.raytest to know it.
        If you are working with solar panels you can use Skelion plugin also.
        Best
        • I Offline
          immcamp410
          Thanks for the advice mr.juantxo, still finding solutions...... need more details
          • JuantxoJ Offline
            Juantxo
            You need to know if a panel is in shadow or not using this 2 vectors and using cosine law
            panel verctor->
            v=Sketchup.active_model.selection[0].normal
            sun vector->
            s=Sketchup.active_model.shadow_info["SunDirection"]
            But you need to know also if there is some object projecting shadow over the panel using raytest with sun vector and some points of the panel. You can modify this step and look for other methods if you need more accuracy...
