    Web dialog fractions conversion
    8 Posts 3 Posters 678 Views 3 Watching
    • G
      Garry K
      My model is set to millimeters 0.001 precision.
      Using a web dialog I enter the following values and use text.to_l to convert
      These are as expected
      1. 400 ends up as 400.000mm
      2. 300mm ends up as 300.000mm
      3. 16" ends up as 406.400mm
      4. 3 7/8 ends up as 3.875mm This one is suspicious
      But then this happens
      1. 2 1/2" ends up as 2.500mm
      Is this a bug or am I doing something wrong?
      I suppose that I could check for '/' and then treat and if found multiply the result by
      25.4 if metric. It appears that I will have to do some testing to see if there are any other conversion issues.
      • G
        Garry K
        After further testing it appears that this is the only conversion that fails ( I'm currently only interested in mm and inches )
        I have tested Version 7,8 and 2013 and all give the same results.
        I have also tested Sketchup's input box and it also gives the same results.
        def get_value( text )
        tmp = text.to_l
        if ( @@metric == true && text.index( '/' ) != nil )
        val = ( ( tmp * 25.4 ).to_s + '"' ).to_l
        else
        val = tmp
        puts val
        return val
        • Dan RathbunD
          Dan Rathbun
          Have you read Thomas' "Dealing with Units in SketchUp" ?
          http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
          Always assume the user wishes to enter values in model units.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            It works for me if I make sure to escape the inch symbol, or use a single quoted string:
            ` n = '2 1/2"'.to_l
            0.0984251968503937
            n = "2 1/2"".to_l
            0.0984251968503937`
            You can test if a string contains a double quoted character thus:
            if num =~ /\"/
            • G
              Garry K
              I'm on a different wave length here.
              If you have a Sketchup inputbox that has a length.
              The model is in millimeters and use precision of 0.001 just because.
              Now the user enters 2 1/2" into the input box ( they will never understand that you need to escape the double quote.
              It comes out as 2.500mm
              This is NOT as expected - regardless.
              I know myself that I work mostly in millimeters but feel quite at home going back and forth. All the other built in conversions work just fine. Just not this one.
              Furthermore - my experience in CAD goes back to DOS. I allow my users ( when I code in C++ ) to enter inches when in millimeters and visa versa. Additionally I allow users to enter mathematical expressions that I evaluate such as:
              in milimetes
              (905 - 20) / 5
              which evaluates as 177mm
              If 95% of logical data entry works - and 5% doesn't - users will naturally tend to see that as a bug.
              But not to worry as I have a work around - but not for Sketchup inputbox as we don't get to see what the user entered.
              • jolranJ
                jolran
                http://sketchucation.com/forums/viewtopic.php?t=36722
                There are some conversion methods in there to take inspiration from..
                • G
                  Garry K
                  Thanks Jolran - this is helpful. I can perhaps add math expression parsing at a later date!
                  • Dan RathbunD
                    Dan Rathbun
                    Yes I think it IS a bug.
                    Today I tested with a model set to decimal feet (0.001) and got this:
                    ` '2 1/2"'.to_l
                    30.0
                    Sketchup::format_length('2 1/2"'.to_l)
                    2.500'`
                    So the inch symbol is ignored.
                    But in a model set to inches:
                    "2.54'".to_l %(#008000)[30.48]
                    So it seems the foot symbol works, IF the numeric is decimal.
                    But IF it is fractional (model set to inches):
                    "2 1/2'".to_l %(#008000)[24.0]
                    **So I agree. It is a bug issue with fractional expressions.
                    ADD: The error also occurs within the VCB (Measurements Box) !**
