    SketchyPhysics working in SU 2013
    24 Posts 14 Posters 15.9k Views 14 Watching
      livebluetooth
      Dear Willeykj,
      I really appreciate your work. Thanks to share the information. I am also facing the same common problem of sketchyPhysics. The sketchyPhysics is not working on SU2013.
      I did all the stuff found on google. Finally after gone through your post it is really helpful. I would like to share the working sketchyPhysics 3.2 with all.
      I have attached the <sketchyPhysics 3.2> which will work on SU2013
      I have tested it on SU2014 it is not working.Nothing gets happen on SU2014.
      <SketchyPhysics3.2.rbz> File size is 6.26 MB.
      while uploading File size and File extension has limitation so I have changed the extension and the file is split into 3 part.
      Please follow the below steps to make one <SketchyPhysics3.2.rbz>
      1)Remove the zip extension of all part.
      Open the First part file in winzip/7Zip
      Extract it into one folder
      Again zip the extracted output files into one zip file
      Then change the extension zip to rbz.
      OR
      2)Remove the zip extension of all part.
      Then by winzip/7zip compression utility combine the 3 parts and make it to one
      Please note that while using <sketchyPhysics 3.2> it will show you that you are using <sketchyPhysics 3.1> because I am not aware about how to make the changes.
      If possible then please someone take the initiative and make the appropriate changes and maintain the correct version.
      Updated Sketchy Physics 3.2 (14 May 2014)(File version will showing 3.1)
      • F Offline
        faust07
        Only a hint:
        Under Board index ... Plugins the author Anton_S is working on MSPhysics (0.1.0 Alpha)on the base of SketchyPhysics.
        It would be the hammer if you could combine your forces. πŸ‘
          deskpilot
          Not sure if there's another thread for this but, isn't there a fix for SP and SU2014 yet? I have loaded the program but it just won't run. Searching the net and one sees various suggestions to open CMD files etc but we're not all pc literate. An suggestions folk?
          Cheers, Doug
            Anton_S
            Cheers, Doug
            Unofficial release: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936#p536443
            • 2 / 2
