    Ideas for TV or Monitor (affordable)
    4 Posts 2 Posters 915 Views 2 Watching
    • pbacotP
      Using a Mac and want to get another TV or Monitor for CAD and modelling. 40-48in is probably OK. So does anyone have some good ideas? This will be a second setup so I can spend more productive time at home, but not wanting to spend as much as I did for my monitor at the office. More in the mid hundreds. I know some people have used TV's for monitors, but IDK what that would be like. Do you see vertical lines? Are the resolutions limited?
      If you use a TV what is the preferred connection these days HDMI or VGA or...? I use DVI dual link on the monitor I have at work. (as I write now, this one is feeling small--only 30"! but it was an expensive DELL)
      • KrisidiousK
        Krisidious
        I used HDMI for my 42" 1080p looks great. I also run (3) 23" LG's under it.
        By: Kristoff Rand
        • pbacotP
          Thanks, Kris. What type is your 42"?
          • KrisidiousK
            Krisidious
            Sanyo 42" 1080p HDTV
            http://www.walmart.com/ip/SANYO-42-Class-LCD-1080p-60Hz-HDTV-DP42841/16401798
            By: Kristoff Rand
