    Asigning colours to elements
    5 Posts 2 Posters 422 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      after a long search i have to ask:
      is it possible to asign a colour to ALL faces within 1 group or 1 component?
      every colour shall become its own values and names and shall be written in model's colour table.
      what ever i try with the api-syntax, i fail....
      thanx stan
      • Dan RathbunD
        Dan Rathbun
        You assign the group's material, and leave all it's faces material set to nil.
        Same for a component.
        I'm not here much anymore.
        • artmusicstudioA
          artmusicstudio
          hi dan, thanx, i know, it is like working in skp itself,
          but when i have to transfer it to vis-software, i sometimes need all surfaces defined, since the importers do not transfer the group's color to the elements inside sometimes. but i will try once more, just not to be wrong on this.
          for that i would like to paint every surface, sometimes also the back-side directly.....
          besides that, i would like to understand the syntax of the coor asignment, somehow i cannot get it from the api guide.
          thanx stan
          • Dan RathbunD
            Dan Rathbun
            Oh OK.
            grp.entities.grep(Sketchup;;Face).each{|f| f.material=grp.material }
            • artmusicstudioA
              artmusicstudio
              hi dan, thanx,
              next step is done!
              this one works:
              @c_step = Sketchup;;Color.new(30,125,180)
              group.entities.grep(Sketchup;;Face).each{|f| f.material=@c_step}
              stan
