    Error: #<NameError: undefined local variable or method
    3 Posts 2 Posters 1.1k Views 2 Watching
      martinspixis
      Hello, can anyone explain to me why I get error msg.: ***Error: #<NameError: undefined local variable or method `field_build' for Visual::Plugin_A:Module>***on this code:
      require("visual_visual_mod.rb")
      require("sketchup.rb")
      module Visual;;Plugin_A
      # module methods, module vars, etc.
        unless file_loaded?(File.basename(__FILE__))
        Visual;;SUBMENU_VisDose.add_item ("VisDose 3D") {
      field_build
      def field_build
      model=Sketchup.active_model
      entities=model.active_entities
      mod = Sketchup.active_model # Open model
      entities = mod.entities # All entities in model
      status = entities.clear! #clear current model
      path = UI.openpanel "Open Data File", "d;\\", "*.txt"
       prompts = ["Alpha; "]
       defaults = ["0.5"]
       alpha = UI.inputbox prompts, defaults, "Please set transparency."
      File.open(path).each_line {|line|
      values=line.split(' ')
      	x1=values[0].to_f
      	y1=values[1].to_f
      	z1=values[2].to_f
      	color=values[3].to_f
      	size=1
      	x2=(x1+1)
      	y2=(y1+1)
          pt1 = [x1, y1, z1]
          pt2 = [x2, y1, z1]
          pt3 = [x2, y2, z1]
          pt4 = [x1, y2, z1]
      case color
      	when 8..1000 then
      		face1=entities.add_face pt1, pt2, pt3, pt4
      		face1.material=[255,0,0]
      		face1.material.alpha=alpha[0].to_f
      		face1.back_material=[255,0,0]
      		face1.back_material.alpha=alpha[0].to_f
      		face1.pushpull size, true
      	when 7..7.99 then
      		face2=entities.add_face pt1, pt2, pt3, pt4
      		face2.material=[255,86,25]
      		face2.material.alpha=alpha[0].to_f
      		face2.back_material=[255,86,25]
      		face2.back_material.alpha=alpha[0].to_f
      		face2.pushpull size, true
      	when 6..6.99 then
      		face3=entities.add_face pt1, pt2, pt3, pt4
      		face3.material=[255,220,25]
      		face3.material.alpha=alpha[0].to_f
      		face3.back_material=[255,220,25]
      		face3.back_material.alpha=alpha[0].to_f
      		face3.pushpull size, true
      	when 5..5.99 then
      		face4=entities.add_face pt1, pt2, pt3, pt4
      		face4.material=[254,254,76]
      		face4.material.alpha=alpha[0].to_f
      		face4.back_material=[254,254,76]
      		face4.back_material.alpha=alpha[0].to_f
      		face4.pushpull size, true
      	when 4..4.99 then
      		face5=entities.add_face pt1, pt2, pt3, pt4
      		face5.material=[128,255,0]
      		face5.material.alpha=alpha[0].to_f
      		face5.back_material=[128,255,0]
      		face5.back_material.alpha=alpha[0].to_f
      		face5.pushpull size, true
      	when 3..3.99 then
      		face6=entities.add_face pt1, pt2, pt3, pt4
      		face6.material=[0,255,0]
      		face6.material.alpha=alpha[0].to_f
      		face6.back_material=[0,255,0]
      		face6.back_material.alpha=alpha[0].to_f
      		face6.pushpull size, true
      	when 2.5..2.99 then
      		face7=entities.add_face pt1, pt2, pt3, pt4
      		face7.material=[0,160,177]
      		face7.material.alpha=alpha[0].to_f
      		face7.back_material=[0,160,177]
      		face7.back_material.alpha=alpha[0].to_f
      		face7.pushpull size, true
      	when 2..2.49 then
      		face8=entities.add_face pt1, pt2, pt3, pt4
      		face8.material=[0,86,255]
      		face8.material.alpha=alpha[0].to_f
      		face8.back_material=[0,86,255]
      		face8.back_material.alpha=alpha[0].to_f
      		face8.pushpull size, true
      	when 0..2 then
      		face9=entities.add_face pt1, pt2, pt3, pt4
      		face9.material=[0,86,255]
      		face9.material.alpha=alpha[0].to_f
      		face9.back_material=[0,86,255]
      		face9.back_material.alpha=alpha[0].to_f
      		face9.pushpull size, true
      	else
      		face10=entities.add_face pt1, pt2, pt3, pt4
      		face10.material=[0,0,255]
      		face10.material.alpha=alpha[0].to_f
      		face10.back_material=[0,0,255]
      		face10.back_material.alpha=alpha[0].to_f
      		face10.pushpull size, true
       styles = Sketchup.active_model.styles
       status = styles.add_style "D;\\xray.style", true
          file_loaded(File.basename(__FILE__))
      Thank's
        Dan Rathbun
        Ignoring other errors ...
        If you wish to make unqualified method calls, from within the module, then the methods must be defined within an anonymous proxy class block.
        This also allows you to make qualified method calls from outside the module, like:
        Visual::Plugin_A.field_build()
          ### CONSTANTS
          ### MODULE VARS
          #{# ANONYMOUS SINGLETON PROXY CLASS INSTANCE
          class << self # this module itself is the proxy object
            ### INSTANCE VARS
            ### METHODS
            def field_build()
              defaults = ["0.5"]
                x1=values[0].to_f
                y1=values[1].to_f
                z1=values[2].to_f
                size=1
                x2=(x1+1)
                y2=(y1+1)
                pt1 = [x1, y1, z1]
                pt2 = [x2, y1, z1]
                pt3 = [x2, y2, z1]
                pt4 = [x1, y2, z1]
                case color
                when 8..1000 then
                when 7..7.99 then
                when 6..6.99 then
                when 5..5.99 then
                when 4..4.99 then
                when 3..3.99 then
                when 2.5..2.99 then
                when 2..2.49 then
                when 0..2 then
                else
                end # case
              } # file each line
            end # def
          end #}# proxy class
          #{# RUN ONCE PER SESSION
              field_build()
          end #}# unless file already loaded
        end # module
        I'm not here much anymore.
          martinspixis
          Thank you, Dan, it works OK now!
