    Offset + Thickness + Groups
    2 Posts 1 Posters 375 Views 1 Watching
    • pingpinkP Offline
      pingpink
      Hi Everyone ,
      I'm trying to write a code to make a real glass size which I want to make all 3 functions of
      Glass Offset , Thickness , and Group's name of " Glass Unit " in one time. From what I can do is to make Glass Offset + Thickness. They are all faces , but I want to convert faces to separate groups at the end. How can I add groups and have a name of glass unit ?
      def face_offset
      	model = Sketchup.active_model
      	model.start_operation( "Face Offset" , true)
      	selection = model.selection
      	entities = model.active_entities
      	arr = []
      	faces = []
      	selection.each{|entity|
      	   if entity.class == Sketchup;;Face
      	     arr.push entity
             $face_offset = 13
      	 $glass_thickness = 6
      	 prompts = ["Offset Width [mm] ", "Glass Thickness [mm] "]
      	 defaults = [$face_offset.to_s,$glass_thickness ]
      	 list = ["",""]
      	 input = UI.inputbox prompts, defaults, list, "Offset Face."
      	 doffset = input[0].to_f
               $face_offset = doffset
      	 berase = true
      	# 1. Offset Glass + Erase outer faces
          arr_glass = []
          arr.each{|entity|
      	   face  = face_offset1(entity, doffset.mm, berase)
      	   arr_glass.push face
      	entities.each do |e|
            faces.push e if e.is_a? Sketchup;;Face
      	# 2. Glass Thickness
          distance = input[1]
          faces.each do |e|
            e.pushpull distance.mm, true
      	# 3. Make all to be glass groups
      	# faces.each do |e|(g=entities.add_group(e.all_connected)
              # g.name="GLASS UNIT")if e.valid? and e.parent==entities.parent and e.class==Sketchup;;Face
      	# end
          model.commit_operation
      • pingpinkP Offline
        pingpink
        I can do it now ! πŸ˜„
        def glass_groups
        	#entities = model.entities
        	arr = []
        	faces = []
        	     arr.push entity
             $face_offset = 13
        	 defaults = [$face_offset.to_s,$glass_thickness.to_s ]
        	 list = ["",""]
        	 berase = true
            arr_glass = []
            arr.each{|entity|
        	   arr_glass.push face
        	# 2. Glass Thickness + Group's Name
            distance = input[1].to_f
            n='Glass unit'
            faces.each do |e|
             # e.pushpull distance.mm, true
        	   g = entities.add_group e
        	   e.pushpull(-distance.mm)
        	   g.name=n
