    Sketchup viewer portable
    3 Posts 2 Posters 3.4k Views 2 Watching
    • G Offline
      glro
      is there a way?
      i tried universal extractor
      doesn't work
      would be useful to have SU viewer on a pendrive
      • Dan RathbunD Offline
        Dan Rathbun
        The viewer writes it's settings into it's own registry hive on PC, so it is separate from the Make or Pro SketchUp settings.
        These viewer registry settings would be left behind on the workstation, but should not cause any problems.
        The more important isssue is if the workstation will have all the required libraries already installed on them. Such as the correct version of the C runtime library. Dot NET libraries, etc.
        I'm not here much anymore.
        • G Offline
          glro
          thank you for these informations
          i don't understand everything, but from what i understand, it should be possible to use su viewer in a portable way
