    Another approach for copyying a compo in a loop - no success
    1 Posts 1 Posters 273 Views 1 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      sorry, i have to try again with another approach:
      this is , what ruby reports first:
      FROM RUBY:
      menues # my module running and ok
      masterdefinitions set # my module running and ok
      master-components defined # my module running and ok
      start masterloop # my module running and ok
      creating top-handrail tubes (followme)-beta # my module running : PROBLEM
      Error: #<NoMethodError: undefined method definition' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:2440:in top_handrails'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:2404:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:2404:in top_handrails'
      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:60
      END REPORT
      this ist the code
      MODULE start_masterloop
      ....some other code
      model = Sketchup.active_model
                      entities = @group_handlauf_mitte1.entities
      		entities.erase_entities entities[0]
      		rl1 = [0, y1, 0]
      		rl2 = [0, y2, z]
                      group = @group_handlauf_mitte1 = entities.add_group
      		entities2 = @group_handlauf_mitte1.entities
      	for mth in 1..@podestnr
      		new_line = entities2.add_line rl1, rl2
      		length = new_line.length
      		pf[mth] =  [0,  0 - @run+@run*@il*(mth-1)+@run*@la*(mth-1)+@ro.abs, (mth-1)*@il*@rise+@mr] #mitte
                      if mth == 1
      		centerpoint = pf[mth]
      		vector = new_line.line[1]
      		vector2 = vector.normalize!
      		edges2 = entities2.add_circle centerpoint, vector2, @thradius
      		kreis2 = entities2.add_face edges2
      		status = kreis2.reverse!
      		entity1 = entities[0]
      		kurvem = entity1.all_connected
      		status1 = kreis2.followme kurvem
      		@group_handlauf_mitte1 = group.to_component
      		defn = @group_handlauf_mitte1.definition
      		defn.name = "@group_handlauf_mitte_compo"
      		status = @group_handlauf_mitte1.explode  # NOTE 1
      		elsif mth > 1
      		entities2 = Sketchup.active_model.entities
      		componentinstance =
          		entities2.add_instance(@group_handlauf_mitte_compo.definition, pf[mth]) # NOTE 2 (= LINE 2440)
          		puts mth # CONTROLL OUTPUT - WORKS
      		new_line.erase!
      END OF MODULE
      what i want to achieve, is to create a component in step 1 of the loop and copy this component to points pf[mth] in the other steps of the loop.
      i desperately try, but always get an error for copyying the component.
      i also tried:
      explode the group, in which the component is created, but then there is not the component left, but the group (no idea how)
      so maybe someone has an idea...
      thank you
      stan
