    Problem with component-definition in a loop
    2 Posts 2 Posters 328 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hello ruby friends,
      i took 2 weeks off to study some programminmg guides etc. for ruby. i could solve some variable-problems, but i cannot find a solution for the following:
      i want to define some master-components, which are copied later in the routine as instances.
      this works well, when i define one component after each other (linear).
      this all happens in one routine like this:
      def_programm
      define compo 1
      define compo 2
      define compo 3
      some other tasks
      copy compo 1 to instance .....
      copy compo 2 to instance .....
      copy compo 3 to instance .....
      BUT
      when i try to make the component definition within a LOOP and define the compnent'S name as ARRAY,
      the components are again created, ok, but the creation of INSTANCES report, that they cannot find a deleted master component.
      so it seems, that the components made within a loop are not visible for the rest of the program.
      i am not sure, if i could explain my problem. in one other topics i was said, i should post the parts of programm code in some special way: could someone tell me, how to do it?
      until then, here is the loop for the component - creation:
       # edit 131107
      require 'sketchup.rb'
      Sketchup.send_action "showRubyPanel:"
      #Add a menu item to launch our plugin.
      UI.menu("PlugIns").add_item("01-ZF"){
      # Call
      programm
      def_programm
      some code
        #DEF PFOSTEN MASTER COMPONENTS AT 0,0,0 AS LOOP
      model = Sketchup.active_model
      entities = model.active_entities
               for pfosten in 0..2
               pfostenname=[]
               pfostenname[0] = "$masterpfostenl"
               pfostenname[1] = "$masterpfostenr"
               pfostenname[2] = "$mittelpfostenm"
               pfm1 = [0, 0, 0+thickness]
               pfm2 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
               pfm3 = [0, 0, 0+thickness+sl-((5/faktor)/100)]
               pfm4 = [0, 0, 0+thickness+sl]
               group = entities.add_group
               group.name = pfostenname[pfosten]
               entities2 = group.entities
               unless pradius<0
               #puts "tube-pole"
               new_line = entities2.add_line pfm1, pfm2
                            length = new_line.length
                            centerpoint = pfm1
      # Create a circle perpendicular to the normal or Z axis
                            vector = pfm2
                            vector = vector.normalize!
                            edges = entities2.add_circle centerpoint, vector, pradius
                            kreis = entities2.add_face edges
                            kreis.pushpull length
               new_line2 = entities2.add_line pfm3, pfm4
                            length2 = new_line2.length
                            centerpoint2 = pfm4
               	      vector2 = pfm3
        	              vector2 = vector.normalize!
        		      edges2 = entities2.add_circle centerpoint2, vector2, pradius/3
        		      kreis2 = entities2.add_face edges2
                            kreis2.pushpull -length2
        else
                           #puts "square-pole"
                           side = pradius.abs
                           #puts pradius
                           centerpoint = pfm1
                           vector = pfm2
                           pts = []
                           pts[0] = [-side/2, -side/2, 0+thickness]
                           pts[1] = [-side/2, +side/2, 0+thickness]
                           pts[2] = [+side/2, +side/2, 0+thickness]
                           pts[3] = [+side/2, -side/2, 0+thickness]
                           square = entities2.add_face pts
                           square.pushpull -length
                           centerpoint2 = pfm4
                           vector2 = pfm3
        puts "creating component in loop"
        puts pfostenname[pfosten]
        puts "Gruppenname " , group.name
        pfostenname[pfosten] = group.to_component
      # BUT THIS COMPONENT IS NOT REACHABLE FOR THE REST OF THE PROGRAMM
      end    # end of loop
      #here the code for copying of components (which works, when the compnents are created oe after each oother within programm
      # PFOSTEN SETZEN
      if $putswitch == 1
      puts "positioning posts"
          pf1 =  [x1+rol-$lwidthplus*(step+multistep-2),  y1-run+ro.abs+multistep*run, z-rise] #links
          pf3 =  [x2-ror+$rwidthplus*(step+multistep-2),  y1-run+ro.abs+multistep*run, z-rise] #rechts
          pf5 =  [0, y1-run+ro.abs+multistep*run, z-rise] #mitte
          pf1p =  [x1+rol-$lwidthplus*(step+multistep-1),  y1-run+ro.abs+multistep*run+run, z] #links
          pf3p =  [x2-ror+$rwidthplus*(step+multistep-1),  y1-run+ro.abs+multistep*run+run, z] #rechts
          pf5p =  [0, y1+ro.abs+multistep*run, z] #mitte
              if (step) / il == podestnr #posledni horni
                      stepcount = 0
              	componentinstance =
      		entities.add_instance($masterpfostenl.definition, pf1p)
      		componentinstance =
      		entities.add_instance($masterpfostenr.definition, pf3p)
      		componentinstance =
          		entities.add_instance($mittelpfostenm.definition, pf5p)
          		elsif   pmod == 1 # na kazdy schod
          			componentinstance =
          			entities.add_instance($masterpfostenl.definition, pf1)
          			componentinstance =
          			entities.add_instance($masterpfostenr.definition, pf3)
          			componentinstance =
          			entities.add_instance($mittelpfostenm.definition, pf5)
          			if (step+1) / il == podestnr
          			componentinstance =
      			componentinstance =
      			componentinstance =
                      elsif
                              #pmodoffset =   2*((il / pmod).ceil+1)*pmod-il
          			(step + (((il / pmod).ceil+1)*pmod-il)*(podestnr-1)) % pmod == 1
                              # verteiler ab modulo 2
          			componentinstance =
          			componentinstance =
          			componentinstance =
      end     # end of PROGRAMM
      edit 131107, thanx to dan
      THANK YOU VERY MUCH FOR HELPING.
      stan
      • Dan RathbunD
        Dan Rathbun
        See the BBcode help page
        You need to use the [ code ] ... [/code ] bbCodes around your code example and it will look like this:
        [code:11ffgczd]
        Some example code;
        a = [1,2,3]
        last = a.pop
        puts last[/code:11ffgczd]
        I'm not here much anymore.
