    SketchyPhysics Help?
    3 Posts 3 Posters 5.4k Views 3 Watching
    • Rafferty94R Offline
      Rafferty94
      Hi all.
      Would anyone be able to point me towards a tutorial for using SketchyPhysics to drop objects naturally on the ground.
      For example, I have a plane full of rocks that I want to place above the ground plane of my model and drop so that when they fall they all could potentially land differently.
      thanks for any help guys!
      • mitcorbM Offline
        mitcorb
        Hi,Rafferty94:
        Bonnie Roskes has recently published a book on Sketchyphysics. I just happened to be looking around for publications and found it. Perhaps you will find it helpful?
        See this link as a start:
        http://3dvinci.blogspot.com/2013/05/my-new-sketchy-physics-book.html
          Absolutly no problem ๐Ÿ˜„
          Draw all your rocks ( similar or not but each as a "group" or component)
          Place them above your Target(s) like inside a column or like a plane depending of what do you want!
          Targets must be trimmed in separated group if they are concave
          And press the button "Run"!
          http://sketchucation.com/forums/download/file.php?id=94890
          They must rolling stones till they will unmoving! โ˜€
          See my little tut ๐Ÿ˜‰
          (here the box is trimmed in some separated smaller boxes )
          http://sketchucation.com/forums/download/file.php?id=94891
          PS Careful SketchyPhysics don't love another plugins!
          So it's better to use it alone in a Plugins folder special for it! ๐Ÿ˜‰
