    Assigning Textures
    6 Posts 3 Posters 765 Views 3 Watching
    • s_k_e_t_c_h_yS Offline
      s_k_e_t_c_h_y
      I'm trying to assign textures (the standard ones), but I'm having a bit of trouble as it just shows up as black faces and was hoping for some direction...
      In the initialization stage of my class I create a new material as follows;
      			@face_material = Sketchup.active_model.materials.add "face_material"
      I receive my path from my web dialog with this bit of code
      			dialog.add_action_callback("face_material") do |dlg, msg|
      				filename = msg
      				if File.exists?(filename)
      					@face_material.texture = filename
      					puts @face_material.texture
      Here is the output of the 'puts' statement so I can tell I'm getting the path ok.
      C:\Program Files (x86)\SketchUp\SketchUp 2013\Materials\Translucent\Translucent_Glass_Tinted.skm
      If I check the face material texture I get nil back so I'm guessing this means that the assignment failed. Is there something about needing say no spaces in the name or needing to double backslash \ the path?
      I create the face and assign the front and back sides with the material
      							face = @geodesic.entities.add_face @primitive_points[p_num - order], @primitive_points[p_num - order - 1], @primitive_points[p_num]
      							face.material = @face_material
      							face.back_material = @face_material
      This face turns out to be black instead of what I picked. I've read a few articles on the subject, but can't find my mistake.
      Sincerely, Sketchy...
      • Dan RathbunD Offline
        Dan Rathbun
        (1) Slashes
        Ruby uses forward slashes. Backslashes are used as escape sequences.
        Example "\t" is a TAB character, "\n" is a newline.
        Either escape (double backslash, or replace with forward slash.)
        filepath = msg.gsub('\','/')
        (2) Scope
        A block delimited with do ... end may has a different scope then a block delimited with { ... }. Generally the curly braced block can see outer variables in more cases than the do ... end block can. So try curlies.
        I'm not here much anymore.
          s_k_e_t_c_h_y
          Thanks a lot for the feedback Dan πŸ˜ƒ
            s_k_e_t_c_h_y
            Hmmm,
            I included your advice and it still does not work. I also tried hardcoding a path (without spaces in case that was it) and it wasn't. The .nil check below is failing
            			dialog.add_action_callback("face_material") { |dlg, msg|
            				filepath = msg
            				if File.exists?(filepath)
            					puts filepath
            					filepath = msg.gsub('\\','/')
            					puts filepath
            					@face_material.texture = "C;/a.skm"
            					if (@face_material.texture.nil?)
            						puts "No worky..."
            Any ideas as to why I can't assign a path...?
            Reference posts....
            http://sketchucation.com/forums/viewtopic.php?f=180&t=3100
            http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/
            Update:
            https://groups.google.com/forum/#!msg/sketchupruby/0St9qMVnro4/TtcTfhOsbHoJ
            Apparently you can't add .skm's directly...
            http://sketchucation.com/forums/viewtopic.php?f=180&t=32643
            Now to find SKMTools... http://sketchucation.com/forums/viewtopic.php?f=180&t=33079
            Ok, SKMTools installed....now windows permissions issues in the plug-in directory that SKM needs for temporary writing..... fun night πŸ˜ƒ
            Most frustrating... Sketchy
            • jolranJ Offline
              jolran
              maybe because Dan suggested you do a gsub BEFORE if File.exists?
              Note: You can also edit in place gsub!(etc..)
                s_k_e_t_c_h_y
                Thanks Jolran,
                You're right that was a short coming in logic, but it was making it into the 'if' anyway. The issue is you can only use .texture to load images, not skm's. TIG wrote a module to extract a .skm and return the texture within so I'm currently integrating that library.
