    Image size layer
    9 Posts 5 Posters 970 Views 5 Watching
    • Y
      yamh
      im doing a NPR render with vray and sketchup.. so when i open the rendered image on photoshop and i insert the hidden line image from sketchup, they dont fit.. the render image size is 1600x1200 and the hidden line image is 1600x1200 as well... anyone??
      http://sia1.subirimagenes.net/img/2013/08/12/mini_13081204321676360.png
      http://sia1.subirimagenes.net/img/2013/08/12/mini_130812043320171043.jpg
      • CarlohC
        Carloh
        have you checked if the dpi from both image are the same?
        • cottyC
          cotty
          Are you shure that the hidden line image (2D export SU?) is 1600x1200? If you change one direction inthe export options, the other is changed automatically (to keep the aspect ratio) and it is probably difficult to get exactly that dimensions.
          my SketchUp gallery
          • Y
            yamh
            ok mow i know they have differents dpi , but how can i change de dpi in vray or sketchup?
            • cottyC
              cotty
              You cannot change the resolution in SU. You can
              • calculate the needed pixel dimensions to fit the rendered image
              • use Irfanview to change the dpi (view with irfanview, press i like info, type in the new values for dpi and apply)
              my SketchUp gallery
              • CarlohC
                Carloh
                since you're using photoshop to merge the images, just type the desired dpi in the picture size information menu. when the picture sizes are really both 1600 x 1200 now with the same dpi they should match.
                • allanxA
                  allanx
                  You cannot change the proportion of the image in SU but in Vray output you can, I do not have Vray but in Maxwell render output I unchecked the proportion box so the linework and render output is the same.
                  Portfolio
                  • Y
                    yamh
                    thanks guys !! i solved this !!
                    • cheddaC
                      chedda
                      maybe the quickest way is cmd t or ctrl t for free transform.
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
