    [Plugin] s4u_Align
    45 Posts 16 Posters 33.4k Views 16 Watching
    • jojo9J
      jojo9
      i downloaded your plugin yesterday and tested it today. Unfortunately, Su13 (Mac) wasnt able to load your plugin and i got following errors in the ruby console:
      undefined method `instance_variable_defined?' for S4U;Module
      Error Loading File s4u_aligntool.rb
      I corrected some errors:
      • i installed a missing ruby: langhandler.rb
      • i changed line 4 to:
      @s4u_menu=UI.menu("Plugins").add_submenu("Suforyou")  if !@s4u_menu #if !S4U.instance_variable_defined?(;@s4u_menu)
      the same applies also for s4u_material!
      now everything works. Please review your code, else thank your very much!
        French Version ๐Ÿ˜‰
        PS Seems there is no Toolbar! ๐Ÿ˜ฎ
        Icon is existing aligntool_large.pngin the files ressource but not appear when Enable Menu Display Tools Bar!
        (works fine for other s4u plugins translated or not)
        PSS I see that I have not translated Titles for s4u-Make Face and s4u-Components! ๐Ÿ˜ณ
        And have some more Plugins to translate! A study summer! ๐Ÿ˜„
        fr.zip
        • hdpvH
          hdpv
          Merci Pilou!
          I will fix it in next version.
          Suforyou
          http://www.sketchupforyou.com
          • C
            Chelmite
            Is there any help on how to use this extension? I want to align a number of components. I watched your video, but I have no idea what you are trying to do in each sequence in the video, nor what keys or mouse actions you are taking.
            Thanks for any help you can give.
            hdpvH 1 Reply Last reply
            • hdpvH
              hdpv @Chelmite
              @Chelmite
              You hold the shift key to select more components.
              Suforyou
              • 3 / 3
