    Change plugin variables within Undo
    4 Posts 3 Posters 493 Views 3 Watching
      maricanis
      In my plugin I define undoable operation with start_operation and commit_operation around my code.
      Operation does next:
      • check some flag value
      • based on flag changes materials of multiple surfaces in the model
      • sets new value to the flag
      If I use undo, after performing operation - materials are changed back correctly, but my internal flag variable is not, so next time I try to run operation staring flag value is wrong.
      Question:
      Is there some way to define which function Sketchup should call when Edit->Undo is clicked?
      I've looked Transaction observers, but it seems like they will trigger for every step of my operation (for each surface's material change), which is not the thing I need.
      I've tried to find similar question on the forum, and also browsed through API documentation, but haven't found solution.
      Thanks in advance,
      Marija
      • tt_suT Offline
        tt_su
        Do you have a reproducible snippet of code?
        By flag, I assume you mean attribute or variable?
          maricanis
          Here is example of code.
          I have global variable @@dl_materials_changed which enables toggling on-off of faces materials in the model.
          Each time user press UI button this function onToggleMaterial is called.
          So with this code Undo correctly switches materials back, but @@dl_materials_changed flag is not changed, so next time I press button in UI it doesn't have correct value.
          def onToggleMaterial()
              Sketchup.active_model.start_operation("toggle materials")
              showFCMaterials()
              Sketchup.active_model.commit_operation()
          def showFCMaterials()
              #load all faces in @faces varialbe
              @faces = getFaces(Sketchup.active_model.entities)
              #Set materials if flag is true
              if @@dl_materials_changed
                  @faces.each {|face|
                      material_name = face.get_attribute("faceData","material_name","")
                      if material_name != ""
                           face.material = materials[material_name]
                      else
                           face.material = nil
                  @@dl_materials_changed = false
              else
                   @faces.each_value {|face|
                      face.material = nil
                  @@dl_materials_changed = true
          • danielbowringD Offline
            danielbowring
            you could store the value/flag on the model instead, then it would also change with the undo steps
            model = Sketchup.active_model
            model.set_attribute('maricanis', 'dl_materials_changed', true)
            model.get_attribute('maricanis', 'dl_materials_changed', false)
