White in Maxwell plugin
Hi!
I've been rendering with Maxwell plugin for Sketchup for a while now, but one problem I can't seem to work out. I want my walls to be white, without the reflection of floor and other items. I have used several materials for the wall, and even though I set rougness to 100%, the reflected color stays.
Please, someone help!
Marieke
Hi Marieke, I think I need to know a little bit more before I try to answer. The area that is circled you want to be completely white?
As far as I know, the color bleed-over from the beige wall on the right is an effect that would take place in the real world in that physical situation, so it looks like that's what is happening. If you're willing to post a Maxwell Model to "Pack'n'Go" then I'd be happy to take a look!
Matt
Register LoginAdvertisement
