    Displaying the Normal of a Polygon
    4 Posts 3 Posters 352 Views 3 Watching
    • J
      jach9009
      I was wondering if there is a way to display the normal of a selected polygon? I have researched it a little bit and it seems like I may need to calculate the normal based on the vertex's of the polygons. Has anyone done this or have any ideas on the easiest way to accomplish this task.
      • Chris FullmerC
        If the polygon is a simple singple plane (which it should be if its a polygon), then you just take the face and get its normal. Let's say you have the single face selected, you can run this line of code in the ruby console:
        Sketchup.active_model.selection[0].normal
        And that will return the vector that represents the polygon's normal. Is that what you're looking for?
        Chris
        All my Plugins I've written
        • A
          Aerilius
          If by polygon you mean a face, then it's easy. If the polygon is just geometry without entities, then it needs to be calculated. But you can use creative solutions, like
          normal = Geom::Vector3d.new( [Geom.fit_plane_to_points](http://sketchup.com/intl/en/developer/docs/ourdoc/geom.php#fit_plane_to_points)(points)[0...3] )
          • J
            jach9009
            Thanks guys thats what I needed.
