    OSX MDI confusion
    7 Posts 3 Posters 933 Views 3 Watching
    • dkendigD Offline
      dkendig
      Hello everyone,
      I am about to start working on improving our OSX support for V-Ray for SketchUp. The biggest issue we have on that platform, is the way SketchUp handles multiple documents being open at the same time. We make our own materials that correspond to SketchUp materials that are in the model, and we also have a set of render options which we attach to the model. On Windows, it's simple, each model gets it's own instance of SketchUp, so inherently everything is separate and clean. On OSX, since our plugin gets loaded once, regardless of how many models are open, our information gets rather confused.
      So I am not sure how to fix this. We need to do 2 things:
      1. know how many models are open, and how to identify each one in a unique and per-session constant way. The model guid changes when the model is modified or saved, and the path is empty if the user has never saved the model to disk. Both of those are useless for this case.
      2. know when a user switches from working in one model, to the next, so we can update our UI and show the proper render options and materials for that current scene.
      We have been scratching our heads about this for the past couple of years, and now that we are approaching a final release candidate, we would like to try to tackle this issue if we can. Does anyone have any ideas?
      For a possible workaround for #2, we could check the SketchUp.active_model when our UI gets focus. For a possible workaround for #1, we could perhaps attach a guid string that we make, to the model's attribute dictionary. I was really hoping that there would be some sort of built in SketchUp functionality that would let us know what is going on though.
      Best Regards,
      Devin Kendig
      Developer
      Chaos Group
      Devin Kendig
      Developer
        Aerilius
        1. As long as you don't need a reference that is persistent over sessions (closing/restarting of SketchUp), a simple object reference to the active model should be enough. Use active_model only the first time when the user selects a tool for a specific model and then store a reference to it so that it doesn't matter whether the user switches focus before completing the action.
          I use for example something like
          @@models = { <Sketchup::Model:0x3456> => <MyToolInstance:0x85698>, <Sketchup::Model:0x478043> => <MyToolInstance:0x946932>… }
          Does that work for your situation?
        2. Would ideally require an onActiveModelChanged AppObserver which does not exist. I don't know if someone has any other trick, but the UI focus event seems like a good work-around (although it would not happen in sync with the model focus change).
          I don't know if a ViewObserver with a check of view.model would be called too often.
          driven
          it is possible to create a unique per model cache, for any number of open windows.
          this is part of working out what I could and couldn't do
          it could defiantly do with a review, but it does work.
          #  Apple Pudding      Wed Jan 11 00;12;31 +0000 2012
          require('sketchup.rb')
          #Sketchup.send_action("openRubyConsole;")
          #module JcB    # later dan...
          def proof      # just type proof after loading
          su_Id=true
          begin
          model = Sketchup.active_model()
          su_Id = model.definitions.object_id()
          has_title = model.title()
          add_title = "Unsaved_" + su_Id.to_s
          # First check if there's an active model name
            if has_title.to_a.length == 1 then
              current_title = has_title
            else
             current_title = add_title
          rescue
             # .. handle error
             #  UI.messagebox("You need an open .skp for this to work")
              puts "You need an open .skp for this to work"
          else
          #check
              puts "model name is; " + current_title.to_s
              ensure
              puts "current_title " + "is a " + defined? current_title
              puts "Congratulations  no errors!"
          begin
          path = "/tmp/"
          # our Directory current_path? If not make one.
          cacheDir = "/tmp/macSUcache"  # is CLEARED after a system Shut Down not Restart which is all I normally do.
          if not File.exists? cacheDir
          then   Dir.mkdir(path + 'macSUcache')
          #check
              puts "current path is; " + cacheDir.to_s
              puts "cacheDir " + "is a " + defined? cacheDir
          rescue
              puts "what now???"
          else
              puts "Congratulations  no errors!"
          begin
          unique_Id =(cacheDir + "/" + current_title.to_s + "_su.txt")
          #check
              puts "this models cache ID; " + unique_Id.to_s
              puts "unique_Id " + "is a " + defined? unique_Id
          rescue
              puts "again?...what now???"
          else
              puts "Congratulations  no errors!"
          ## Proof
          begin
          # Create/open a current model file in read-write [adds new to end of existing] mode, use "w" for over-writing
          f = File.open unique_Id, "a+"
          # Write an array of Strings to the file
          nums = [["\n"] + [Time.now] + ["", "", "", "", "", ""].sort_by { rand }]
          f.puts  nums
          #check
            #  puts "the File; " + unique_Id.to_s + " is now open? " + File.exists?(unique_Id).to_s
              puts "f " + "is a " + defined? f
          rescue
          else
              puts "Congratulations  no errors!"
          #should return true   is now writen
          # Rewind the file, read its lines, and print the third line
          f.rewind
          f.readlines.join
          ensure
            f.close unless f.nil?
          #check
           puts "Congratulations  no errors!"
           puts "this File; " + unique_Id.to_s + " now closed? " + f.closed?.to_s
           end #begin
           end #def
          when you enter 'proof' it returns individually identified windows in the same session.
          proof
          model name is; Unsaved_143187840
          current_title is a local-variable
          current path is; /tmp/macSUcache
          cacheDir is a local-variable
          this models cache ID; /tmp/macSUcache/Unsaved_143187840_su.txt
          unique_Id is a local-variable
          f is a local-variable
          this File; /tmp/macSUcache/Unsaved_143187840_su.txt now closed? true
          Tue Jul 09 01;56;30 +0100 2013
          as a further experiment I attached to the v8 Undo Log and it would bring up the individual models tool history.as they say, the proof is in the puddingIt's a rough experiment, but it worked with v8's undolog
          • dkendigD Offline
            dkendig
            The definitions object_id never changes in a given session? I just tried to find a case where it changes, and I can't find one, but I'm scared to make that assumption if it's not true 100% of the time. I don't want to use the window title, because you can have two files with the same title, or no title at all. None of this needs to be human readable, I just need to be able to differentiate between the windows reliably, quickly, and with as little code as possible. I do like just using a value in the SU model, rather than having to modify or retrieve an attribute dictionary value. I prefer to avoid modifying attribute dictionaries when possible, as that can lead to some plugin conflicts.
            Devin Kendig
            Developer
            • dkendigD Offline
              dkendig
              Just got a reply form Paul on the SketchUp Extensibility Team:
              Yes, I believe that would work fine. However, I recommend using the Entity member entityID instead, like this: Sketchup.active_model.definitions.entityID. This one also doesn't persist between sessions, but it is a unique index across all entities Sketchup has loaded (even with multiple models), and active_model.definitions is a SketchUp entity.
              So there we go, a unique (even across multiple models) ID that we can rely upon! Thanks for pointing me in that direction.
              Devin Kendig
              Developer
              • dkendigD Offline
                dkendig
                also just noticed that this topic has already been discussed in this thread: http://sketchucation.com/forums/viewtopic.php?t=43219 ::blushes:: whoops!
                Devin Kendig
                Developer
                  driven
                  that does seem to work
                  if you want a persistent reference you can add an xattr to the active model file...
                    def only_iff
                          modName = Sketchup.active_model.title
                          modPath = Sketchup.active_model.path
                          modEntID = Sketchup.active_model.definitions.entityID
                        case
                         when modName.to_a.length == 1 then
                          remove_old = %x(xattr -d test "#{modPath}" 2>&1) if  (%x(xattr -p test "#{modPath}" 2>&1)).length > 0
                          perSistent = %x(xattr -w test "#{modEntID}"  "#{modPath}" 2>&1)
                          puts modEntID  # but could be any persistent reference
                         when modName.to_a.length == 0 then
                              Sketchup.send_action('saveDocument;')
                              UI.messagebox "Save model and retry"
                         end #case
                       end # def only_iff
                  then in another session you can check if it's been thru your mill before.
                         %x(xattr -p test "#{modPath}" )
                  just thoughts
                  john
