    The Atrium
    6 Posts 5 Posters 709 Views 5 Watching
      andre51
      From vision to reality..
      This is the first time I've used Thea but still have a lot to learn.
      The Vision
      Office building atrium under construction.
      Reality
      • ely862meE Offline
        ely862me
        Fantastic work !
        I would reduce the noise a bit though !
        Elisei (sketchupper)
        Come and See EliseiDesign
        • allanxA Offline
          allanx
          Nice work Andre...
          allanx
          Portfolio
          • N Offline
            notareal
            If you used TR1/TR2 or other progressive render medoth you can use supersamping set to high, it will reduce noise.
              andre51
              Thanks for the comments - I'm going to try notareal's suggestion..
              • cheddaC Offline
                chedda
                It looks great. My only critique is the ceiling cut off line. The photograph looks a lot taller without it (portrait helps a lot also). I would have even hidden it, if it was a problem. A bit of artistic license !
                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
