    How to join a closed user group
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    5 Posts 3 Posters 8.4k Views 3 Watching
    • C
      CaryInVictoria
      The FAQ says the following about this:
      "Where are the usergroups and how do I join one?
      You can...
      ...If a group requires approval to join you may request to join by clicking the appropriate button. The user group leader will need to approve your request and may ask why you want to join the group..."
      What does "clicking the appropriate button" mean?
      • ely862meE
        ely862me
        I believe you have to go to User Control Panel/Usergroups , check what you want and then at the bottom left you have some options and Submit, then it's up to the leader !
        Never used it though !
        Elisei (sketchupper)
        Come and See EliseiDesign
        • C
          CaryInVictoria
          I had already attempted what you suggest. Here is the usergroup I'd like to join (under control panel/Usergroups:
          "Plugin contributors
          This is a group of members who are generously and often freely contribute with different plugins, update them regularly and provide ongoing support for the whole SketchUp community.
          This is a closed group, new members can only join upon invitation of a group leader."
          The problem is I am unable to select this group by clicking the button to the right of the group name/description. The button looks no different after I click it as before, and there is no visual clue that it has been clicked. If I click the button for an open group, a little dot appears on the button and I can proceed. I naturally assumed this is the button being referred to in the FAQ ("...If a group requires approval to join you may request to join by clicking the appropriate button.") Same problem with all closed groups.
          Should it matter, I just joined sketchUcation yesterday and have the free membership.
          C'mon, why is my question so tough? Many of you out there must know to do something so simple as making a request to join a private group.
          Cary
          • GaieusG
            Hi Cary,
            Your questuion is not "tough" - you are only a bit impatient to wait for the proper person to answer. πŸ˜‰
            So there are usergroups. In fact, there are a lot more than you can even see as there are many "hidden" ones, too - mainly for beta testing plugins in (also) hidden subforums.
            As for the "publicly viewable" usergroups; there are some that you can freely sign up, there are some that you can request membership and there are some that are closed.
            This particular "Plugin contributor" usergroup is in fact completely empty for the time being. We are considering populating it along the development of our "Plugin Store" plugin and (possibly) adding some further/additional privileges/forum permissions to its members. Obviously it is a "closed" group and only esteemed members (plugin contributors - as it says) will be members. Similarly to the "Top SketchUcator" usergroup whose members "are known as exceptionally active and helpful as well as highly skilled members of the SketchUcation Community Forums. This is a closed group, new members can only join upon invitation of a group leader".
            It is also a "closed" usergroup which means that only forum administrators (like myself) can add new members (see attached screenshot of the admin panel). I hope this explanation is sufficient and clarifies some issues around usergroups.
            Also, I am moving this topic to the Corner Bar / Ideas box & board issues subforum (where it should belong).
            • C
              CaryInVictoria
              Gaieus,
              Thank you for your very clear answer.
              It was not so much as impatience, as perplexity. To me, it was those I had asked, "How do I copy an object in Sketchup, rather than move it?", and having over 50 people read the question, without getting a single answer.
              You could avoid problems like this very easily: whenever someone clicks on a disabled button, display an explanation for why they cannot make that selection.
