    Angle between north and face
    9 Posts 4 Posters 969 Views 4 Watching
    • K
      krisjaniszakis
      I have come a cross several posts about angle between but none of them answered my question.
      I want to calculate angle between north and any face in model.
      There should not any restriction if i change north or model.
      #the way how i get north angle north_angle = Sketchup.active_model.shadow_info['NorthAngle']
      Below is algorithm what I want to achieve:
      [pre:2rvuqfdo]x=north_angle
      y=face_angle
      z=angle_between
      if(x>360)
      z=y
      else
      if(x>0)
      if(x+y>360)
      z=x-360+y
      else
      z=x+y
      end[/pre:2rvuqfdo]
      • K
        krisjaniszakis
        Can some one see:
        1. why if I change north angle result is not changing?
        ` north_angle = Sketchup.active_model.shadow_info['NorthAngle']
        north_vector = Y_AXIS.clone
        north_vector.z = 0
        flat_normal = entity.normal.clone
        flat_normal.z = 0
        point = ORIGIN
        up = Z_AXIS
        rotation = north_angle.degrees
        tr = Geom::Transformation.rotation(point,up,rotation)
        north_vector.transform (tr)
        angle = (flat_normal.angle_between(north_vector)).radians
            if flat_normal.x < 0
               angle = 360-angle
            else
               angle
            end`
        • jolranJ
          jolran
          Hi!
          No response ey? I give it a try.
          Maybe this code is part of a larger piece, otherwise I have a little trouble following your logic.
          Have never used shadow info, and do not have time to look up the methods revolving that.
          Does it really return an angle?
          What is entity ? a face?
          Unless you are going to use those variables later why not just enter:
          tr = Geom::Transformation.rotation(ORIGIN, Z_AXIS, rotation)
          Does not really matter for solving this problem though..
          Try putting a bang to it! Edit in place..
          north_vector.transform! (tr)
          • Dan RathbunD
            Dan Rathbun
            @krisjaniszakis said:
            Can some one see:
            north_vector.transform(tr)
            ](http://www.sketchup.com/intl/en/developer/docs/ourdoc/vector3d#transform)":d4kps6d6]The original vector is unchanged by this method.
            ](http://www.sketchup.com/intl/en/developer/docs/ourdoc/vector3d#transform!)":d4kps6d6]The vector itself is modified.
            I'm not here much anymore.
            • jolranJ
              jolran
              Hi Dan.
              Yes modify the vector in place was the idea. Bad one ?
              Found a roundup regarding shadow info that might be intresting for Kris:
              http://sketchucation.com/forums/viewtopic.php?f=180&t=28829&p=250402&hilit=northangle#p250402
              Havent delt with shadow info before so I can only hint some links..
              • K
                krisjaniszakis
                @jolran said:
                Hi!
                I just wanted to automating angle between north and face.
                With entity I meant "face".
                Here is updated code
                flat_normal.z = 0
                north_vector.z = 0
                point = ORIGIN
                up = Z_AXIS
                angle = (north_vector.angle_between(flat_normal)).radians
                       angle = 360-angle
                    else
                       angle
                    end`
                And here is Sketchup screenshot with my experiment.
                http://s8.postimg.org/dco1b0rrp/face2.jpg
                For this example script gives that angle between will be 100but not 50, where is the problem ?
                • jolranJ
                  jolran
                  Hi!
                  I think it's important to determine what you mean angle between north and face.
                  I wonder if it's the face normal you want to work with in this example?
                  Maybe that why youre not getting the result you was expecting.
                  (if the face is vertical al the time(not flat on the ground), then the normal vector comparison should be a reliable method.)
                  You might perhaps be happier working with some of the face edges?
                  If your face is fairly uncomplex and you know that a particular edge has a min or max X,Y,Z value you can retrieve that edge and use edge.line[1], and do a comparison from there.
                  Just an idea..
                  • JuantxoJ
                    Juantxo
                    I'm not sure what are you looking for but here you have the
                    angle between north an a vector normal to face (with z=0) (Not valid for face in xy plane)
                    northvec=Geom;;Vector3d.new( Math;;sin(Sketchup.active_model.shadow_info['NorthAngle'].degrees), Math;;cos(Sketchup.active_model.shadow_info['NorthAngle'].degrees),0)
                    vec=face.normal
                    vec.z=0
                    result= northvec.angle_between(vec).radians
                    • K
                      krisjaniszakis
                      Thanks it was the thing I was looking for πŸ˜„
