    Multiple dialog scope issue on the PC
    24 Posts 4 Posters 1.5k Views 4 Watching
      Back tot the side topic of best practices:
      It's generally considered best practice to separate content, layout and behaviour. That means all CSS in a .css file and all JS in a .js file.
      And I've never heard of void(0) as best practice. I find it often in Bad Practices lists:
      http://www.quirksmode.org/blog/archives/2005/06/three_javascrip_1.html#link3
      http://stackoverflow.com/questions/3498492/javascriptvoid0-vs-return-false-vs-preventdefault/3498566#3498566
      • H Offline
        honkinberry
        Both of those links that you sent merely say it is bad form to put javascript into the href, which is true.
        The javascript:void(0) is the recommended practice, indicating that the onclick handler is to take precedence.
        In fact, the whole point of it is so that it onclick handler doesn't have to return false.
        (See here: http://stackoverflow.com/questions/134845/href-attribute-for-javascript-links-or-javascriptvoid0)
        But good to know that was the issue!
        Many thanks for your tireless attention to detail on every conceivable issue.
        --J
          But when would you use void(0) in anything other than the HREF?
          I still agree with with the this answer:
          http://stackoverflow.com/a/134957/486990
          There's a lot of information floating around which is lingering around from the older days. When going through best practices guides of well known web designers it's always to avoid inline JS. Which then removes void(0) from the equation completely.
          No worries. I had some spare time while I was rendering. πŸ˜„
          And the WebDialog has been a source of so much oddity that I felt a strong inclination to check it out myself. I reckon it's still worth reporting, so if you're heading into Boulder then give them a nudge. πŸ˜„
          • Dan RathbunD Offline
            Dan Rathbun
            I disagreed 3 years ago when we discussed this issue, and still do.
            Read my detailed explanation in this old thread: Webdialogs and Javascript void
            Any more discussion on this offtopic, can be done in that thread, if you wish.
            I'm not here much anymore.
            • 2 / 2
