    Any smokers here? Wanna quit?
    822 Posts 42 Posters 288.2k Views 42 Watching
    • olisheaO Offline
      olishea
      nah I think a case/carton is an exaggeration maybe? 😄
      Silk Cut cigarettes, for example, have a nicotine strength of 0.3mg so 20 x 0.3mg=6mg nicotine = 1 packet of 20 cigarettes. Obviously if you smoke a higher strength brand you need a higher strength liquid.
      2ml a day? Don't worry mate I go through 10ml a day sometimes 😄 Hardcore vaper! 😄 My Kayfun absolutely drinks it, but you get amazing flavour.
      I wouldn't concern yourself too much mate, when you have quit for a couple more weeks try reducing your nicotine to 12mg. I'm on 6mg now and will probably go down to 3mg quite soon.
      Stefan, the cons of your mechanical mod are the advantages I take for granted (such as the safety)....I didn't realise the power drops off over time, but it makes sense now. I always love the look of a mechanical mod though.
      Gareth.....VW just keeps the wattage consistent over time. Even if the resistance of the atomiser changes (like they do) the wattage will remain constant by self-regulating the voltage. Does that make sense?
      But to be honest, I keep my provari in voltage mode. I don't piss around with wattage and all that....I see no difference really. If I need more voltage I just increase it, really simple.
      So, I use my Provari P3 just like I used my Provari 2.5; I just change the voltage as and when I need to. Vaping does not need to be complicated.
      The P3 is just like the old Provaris, you just get a few more options....and you can change the colour of the LED through the menu!! The display also tells you how much battery % is remaining, the resistance of the coil, The voltage and the wattage....all made easier through the OLED screen which simply just allows more information on-screen. It is great to see the battery % remaining though....other than that, it's still a good old Provari device.
      Oh.....and it comes with an extension cap that blends into the body of the device now. So now you don't need to buy a separate extension cap to run 18650 batteries.
      oli
      • K Offline
        kwistenbiebel
        Happy with small and simple things 😄
        An I-stick 20 Watt and Derringer on top.
        http://i.imgur.com/0WybjaK.jpg?1
        • olisheaO Offline
          olishea
          Nice!
          So....educate me. How come you can vape at such high wattage without it tasting burnt? Seems when you go sub ohm the wattage is ramped right the way up....why is that?
          oli
          • bazB Offline
            baz
            @olishea said:
            Nice!
            I'm up for a bit of education too...
            • soloS Offline
              solo
              Thanks for heads up, I just bought a 30w version in chrome, for when I leave the house (work from home) as my Provari is a heavy monster.
              So far it's awesome, great power for a tiny mod.
              http://www.solos-art.com
              • K Offline
                kwistenbiebel
                @olishea said:
                Nice!
                That Derringer is a 'dripper' (rebuildable dripping atomizer). A dripper can take very high wattages, mostly because they provide big airflow and because the 'chamber' is bigger.
                The newer 'sub-ohm tanks' (Kangertech Subtank etc..) are clearomizers that can take higher wattages as well.
                It is a different kind of vape than a Kayfun, way more aery and geared towards direct lung inhale.
                I use them once and a while just for variation, but in general I prefer a Kayfun kind of vape with a tighter draw. I use my Joyetech Egrips for that. Very stealthy vape with a nice tight draw and rebuildable coil.
                ps: that P3 with the Kayfun looks very sharp 😄
                • olisheaO Offline
                  olishea
                  I thought I'd try out all this sub ohm business. This is the Kanger Subtank with 0.5 ohm organic cotton coils.
                  I tried my normal e liquid and it's way too harsh. Too much nicotine and too much PG for sub ohm.
                  I also got the Invader Mini 50 watt mod. It's actually waterproof and smash proof (apparently).
                  Anyway, I mixed up some 3mg E liquid, 85% VG, 10% Flavouring......this thing RIPS!! I can't believe how much vapour comes out! It's so smooth and there is only the slightest throat hit from the nicotine/flavouring. It produces 10 times more vapour than my Kayfun, it's actually quite funny.
                  You need to do a direct lung inhale....but after 5 mins of practice I'm loving it!!
                  http://i654.photobucket.com/albums/uu269/olishea/Mobile Uploads/1FFDCC69-5741-4B71-A591-7BFEF9311E93_zpsfknd1cmq.jpg
                  oli
                  • charly2008C Offline
                    charly2008
                    I stopped smoking abruptly on May 20. I asked myself, what does Smoking do for me. The answer I gave myself:
                    • smoking is unhealthy
                    • Tastes awful
                    • is very expensive
                    and this I say to myself every day.
                    I was told repeatedly by former smokers, all takes place only in the mind.
                    • K Offline
                      kwistenbiebel
                      • Tastes awful
                      • is very expensive
                      Fantastic!
                      I am thinking to quit vaping as I suffer from dehydration easily.
                      • olisheaO Offline
                        olishea
                        I'm cutting my nicotine to zero and just gonna vape when I'm bored....I like the process of vaping not the actual nicotine.
                        Well done Charly....it's good you had that moment of seeing sense; many people never get to that stage.
                        oli
                        • GarethG Offline
                          Gareth
                          Oli, maybe one day you will have a topic titled :
                          "Any Vapers Here ? Wanna Quit?"
                          • olisheaO Offline
                            olishea
                            haha true!
                            I don't think I'll ever truly quit vaping though. Man has smoked for millennia; some people like it and some people don't. Even if I used no nicotine I would still vape just to relax.
                            I never really wanted to quit smoking....I just had to because I felt like I was killing myself. I think vaping provides a good middle-ground between smoking and quitting completely; I owe my life to e-cigs!
                            Even if I just vape after a meal or with a stiff drink....it makes me happy and I really enjoy the taste. #ohmlife
                            oli
                            • GarethG Offline
                              Gareth
                              Yep, well said mate.
                              I went to a party on Saturday night, it was held in a hotel function room, and ended up having to join the smokers outside while it was p!ssing down with rain....the venue didn't permit vaping indoors...!!
                              bugga eh ??
                              • olisheaO Offline
                                olishea
                                "Stealth Vaping" is your friend. I stealth vaped on a plane recently!! Joined the mile high vaping club! lol
                                oli
                                • soloS Offline
                                  solo
                                  Stealth vape, Coke mod.
                                  • jujuJ Offline
                                    juju
                                    [attachment=0:2fg289m0]<!-- ia0 -->can_mod.jpg<!-- ia0 -->[/attachment:2fg289m0]
                                    that looks like a rendering, show us the x-ray view... 😎
                                    • bazB Offline
                                      baz
                                      Me too!
                                      Watch out tho, I managed to set off a smoke alarm at home at 3oc in the morning... missus was not happy.
                                      • michaliszissiouM Offline
                                        michaliszissiou
                                        Count me too.
                                        Using an iStick (40W from Eleaf) and an Aspire Nautilus head. Additionally a GS air-M head, which gives a more pleasant vaping on certain flavors-juices. (IMO of course)
                                        Good bye ash trays….
                                        BTW (under blender) it was my last ash tray concept for heavy smokers (and chocolates lovers as well he he )
                                        https://dl.dropboxusercontent.com/u/24090090/dragonashtray.jpg
                                        • GarethG Offline
                                          Gareth
                                          How do you stealth vape when everyone sees a thumping great big Provari emerge for your pocket ?!! 😆
                                          Was at another pub last week and was vaping away and a friendly staff member asked "Excuse me sir are you vaping Nicotine."
                                          I replied "No. Is that OK because I woudn't want to offend anybody?" (I usually ask if it's ok to vape and most venues permit it, but I sometimes forget to ask)
                                          She said "That's fine as long as you don't vape nicotine"
                                          To which I replied "Thank you for asking. Do you serve Eggplant, Sweet Potato, Potato, Green Peppers, Cauliflower, Tomatoes or Mushrooms with meals in the Dining Room ?"
                                          "Yes we do, I have a feeling you are going to make a fool out of me !"
                                          I said "My intention isn't to make a fool out of you, but as you have probably guessed, they all contain small amounts of nicotine"
                                          I lied....my vape did contain nicotine, it was 6mg. But what the heck...I say it's trivial....and I'll wear the barrage of criticism if I am wrong...!!
                                          Anyhow, you would need to eat huge amounts of those vegetables to give yourself nicotine poisoning.....but she didn't ask me that question..! 😠
                                          PS....I may be wrong about the Mushrooms !! 😆
                                          • bazB Offline
                                            baz
                                            @gareth said:
                                            Eggplant, Sweet Potato, Potato, Green Peppers, Cauliflower, Tomatoes or Mushrooms."
                                            So where can I get those flavours? 😄
                                            No seriously, maybe time to start sharing your favorite E-liquids...?
                                            My current fave is '925' from GoodLifeVapor. But I am wasting a lot of hard earned cash trying other flavors which don't do it for me.
                                            Also, there seems to be a lot of conflicting info out there on what constitutes a 'good' liquid, in terms of quality of ingredients, quality control etc.
                                            Whaddya reckon?
                                            (5 months smoke free this saturday).
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 41
                                            • 42
                                            • 35 / 42
