    Any smokers here? Wanna quit?
    822 Posts 42 Posters 448.7k Views 42 Watching
    • soloS
      solo
      FYI, I get great battery life, I vape 2x more than I smoked (2 packs a day) and my battery lasts more than a day.
      http://www.solos-art.com
      • olisheaO
        olishea
        @gareth said:
        Hiya Oli,
        Money isn't the dealbreaker really, something reliable and of good quality is though. And getting everything I need all at once is also important.
        And I am getting a little confused when I see words like atomiser, cartomiser and clearomiser...!! Some of the deals i read say these are extras...which is even more confusing.
        I'll get there in the end....but need to be active about this while I am still keen.
        The atomiser/clearomiser/cartomiser is the part that turns liquid into smoke. A.K.A. Atty/Atties for short.
        They generally come in 2 sizes....small ones like the EGO or EVOD and 22mm varieties like the ones Pete, Chris and I use. The 22mm atomizers are generally the higher-end ones, hold more liquid and give better flavour.
        Drippers are a type of atomizer that don't generally hold any liquid and need to be direct dripped with liquid...not something you can use out and about but they are known for best flavour/vapour production, but again, limited to a home setup.
        I can only go off what I and others here have tried and enjoyed....
        I would stay away from rebuildable atomizers (or genesis style) at first. They will confuse you and distract from the vaping experience. They take a few attempts to get right and a beginner would become lost in volts, watts, resistance, coils etc. Rebuildable atomizers include my Kayfun 3.1 and the new SQuape. They are customisable as you can change air flow and also flavour, throat hit etc by tweaking the coil.
        The most popular 22mm atomisers are the Vivi Novas and Innokin SVDs....generally due to the price and tank capacity. These do not need to be rebuilt; you just buy new coils and screw them in (cheap).
        The "mod" is the battery part of a vaping device. Investing in a good mod means you only ever need to upgrade your atomiser if you need to.
        I have only ever used the Provari and it really is excellent, only recently I bought the big battery mod to keep at home. Again, I would go for the normal size over the mini for battery life. The Provari is a 22mm mod so you will need a 22mm atomizer to fit right.
        When you have chosen your mod, choose your atomiser. There are so many to choose from but make sure they have a 510 connection to mate with the Provari.
        Basically you need a 22mm mod, 22mm atomizer, replacement coils, E-Liquid, 2 batteries and a charger.
        You seem to be tending towards a better rig so this is why I recommend the 22mm setup over something like the EVOD. It also means you can start thinking about better atomizers or even rebuildables in the future.
        The EVOD is a fantastic bit of kit which I use on nights out due to size, you wouldn't be disappointed and they are quite cheap. It's up to you how you take this...either by a cheap setup to try out vaping or buy the best and never smoke again. I can safely say with a Provari and a decent atomiser you won't smoke again.
        oli
        • GarethG
          Gareth
          Thanks Oli......that is very helpful.
          I might PM biebel and find out where his source is....Adelaide doesn't have much to offer and there are no walk in shops here that sell them
          • BoxB
            Sounds like an ideal business opportunity there in Adelaide.
            • GarethG
              Gareth
              Yeh..!!
              There are a couple of Web based 'eShops' who are (or claim to be) in Adelaide....they could be anywhere really couldn't they ?!!
              I reckon eShops are less risky than renting expensive retail space and if the government happens to change the rules for eCigs and vaping, it will have less impact on their businesses if things turn pear shaped.
              But from my point of view, a walk in shop would be handy and less confusing than the websites.
              • olisheaO
                olishea
                It seems to me most shops only sell Ego devices. I've never been in a vape shop that has a range of 22mm mods for example, in fact, I've never even seen an EVOD in a walk-in shop. It's an internet dominated industry.
                In the UK I see most vaping devices being sold from corner shops and petrol stations, which is great but there is no choice.
                I got the impression somewhere that Australia may be strict on e-cig regulation so perhaps that's why you won't find many shops. I may be completely wrong, but that's what I heard.
                There is an aussie vaping forum, might be worth a try posting a question on there to see where people go for better setups. Kwistenbiebel may not reply for a few days so at least you can get cracking with information from that forum?
                If your heart is set on a Provari then all you need to do is choose your 22mm atomiser.
                I will ask for recommendations on the vaping forum I use and see what people say....like I said, we can only recommend either the vivi nova, innokin SVD or the kanger pro tank because that's all we've tested in that size. Apart from the Kayfun which is rebuildable but truly excellent.
                I highly recommend a Kayfun but not as a beginner setup, try and stay away from rebuildables until you have found a nice E-liquid and are confident with how you like to vape.
                Will let you know what the forum comes back with....shouldn't be too long. πŸ‘
                oli
                • GarethG
                  Gareth
                  Thanks Oli πŸ‘
                  • olisheaO
                    olishea
                    Just to avoid confusion, the innokin atty is called the iClear30....the SVD is the mod, not the atty. Sorry about that.
                    oli
                    • olisheaO
                      olishea
                      Gareth,
                      Looks like the Vivi Nova or Innokin iClear 30 are the only 22mm atties that are suitable.
                      The Vivi Nova is a tried and tested favourite but the Innokin also has a good name. Both have replaceable coils, so that's easy and cheap.
                      If you go for the Vivi Nova make sure you get the latest version.
                      Innokin also sell a cheap mod called the SVD but I think you will find the Provari better quality.
                      Again, you will need:
                      A 22mm mod, Vivi Nova or iClear 30, Spare replacement coils, 2 batteries, a charger and plenyty of E-liquid.
                      How many do you smoke a day? If you smoke around 20 then go for a nicotine strength of 18-24mg.
                      24mg may blow your head off so perhaps try the 18mg first.
                      oli
                      • GarethG
                        Gareth
                        I smoke a pack a day (Dunhill) so that's 25 a day and I've been doing that for 30 years.....and at $19 a pack it wont take long before I get my money back on the cost of vape kit, let alone my health...!
                        • olisheaO
                          olishea
                          I saved so much money and you will too. It makes you wonder how/why we pay that much for cigarettes!
                          You want the E-liquid to completely satisfy your nicotine craving so go for an 18mg or 24mg liquid to begin with. Like I said 24mg may be a bit too much but at least you will have more than enough nicotine to stop any craving.
                          oli
                          • soloS
                            solo
                            I started with 24 and 18, now I'm on 12, tried 8 but not quite ready to go so low.
                            • GarethG
                              Gareth
                              I've just ordered some 18mg e liquid from http://www.niceliquid.co.nz/ ...it'll take a while to arrive here so i have a little time to decide on my setup
                              • soloS
                                solo
                                Tried these guys?
                                Suspended Domain
                                (www.vapebar.com.au)
                                • olisheaO
                                  olishea
                                  Or these guys?
                                  http://www.vapeking.com.au
                                  Vivi Nova V3:
                                  http://www.vapeking.com.au/vision-maxi-vivi-nova-kit-v3-multicoil/
                                  Vivi Nova replacement coils:
                                  http://www.vapeking.com.au/vivi-nova-mini-mega-atomizer-replacement-v3/
                                  Innokin iClear 30:
                                  http://www.vapeking.com.au/innokin-iclear-30-dual-coil-clearomizer-tank/
                                  Innokin iClear 30 replacement coils:
                                  http://www.vapeking.com.au/innokin-iclear30-replacement-coil/
                                  Pete, can you recommend Gareth a good resistance coil if he goes with the Vivi Nova? πŸ‘
                                  oli
                                  • soloS
                                    solo
                                    To be honest Gareth I'm not as geeked out as most guys as far as vaping goes, I have a Provari main unit (I guess the word is mod) which I can set the voltage, there are lots of other settings to play with but I have no need as I have two settings only that I like.
                                    Then you get the tank part with the coily-sparky bit (atomizer I believe) I only buy Vivi Nova as it works great and simple to use.
                                    I have 5 tanks, one mod and two batteries and I buy the atomizers in packs of 10 (they cost $12 for 10 and each one lasts about a week)
                                    I have tried a few different atomizers (all Vivi Nova but different resistances) and find 2.8 ohm the best as it lasts longer and does not burn the liquid giving a foul taste. I set my mod at 4.6 volts for tobacco and 4.4 for fruity flavors. The reason I have 5 tanks is I do not bother cleaning out tanks if I want to change flavor, I have a dedicated tank for each flavor I like because I'm lazy and I want to vape and not tinker around. πŸ’š
                                    Vaping is easy, do not get confused and scared by all the jargon, I'm like an Apple user of Vaping, nice shiny vape that just works, no fiddling around.
                                    • stefanqS
                                      stefanq
                                      I'm thinking to buy this guy, but the mini version, to fit my ego's. It has a pyrex glass tank, it's glue free, and works with evod or protank resistance. It's chrome plated brass, not stainless steel, but for the price ( costs like two evods) I think it's brilliant.
                                      I'm sorry I don't have it, to make a good review, but I heard only good things about it. At the end of the day, it's just another clearomizer, with bottom coil, and it does what is suppose to do.
                                      Gareth, regarding the mod, just go with the provari, because you'll end up with one sooner or later. It's the standard, everything on the market is compared with it.
                                      Be careful with the nicotine, I was a red marlboro smoker, so a 24 mg strength nicotine was perfect. If the nicotine strength is not enough, you won't find satisfaction, so the need for cigs won't go. I'm on 12mg now, and I think I'll go for 8mg next month.
                                      Good luck!
                                      Here is the image with the clearomizer I'll buy next:
                                      PS: It's called " Davide Glassomizer"
                                      • GarethG
                                        Gareth
                                        Well it's looking like a Provari and Viva Nova v3.....now all I have to do is wait...!!
                                        Unfortunately I need to order from two separate websites....what are the odds of both arriving on the same day..??!! πŸ˜†
                                        Thanks for your help and advice Oli, Pete and Co. πŸ‘
                                        • GarethG
                                          Gareth
                                          Provari (plus 2 x 18650 batteries, charger, extension cap & carry case...from Vapebar
                                          Vivi Nova V3 ( x4, plus 10 x 2.5 Ohm spare coils)from VapeKing
                                          Lots of e juices, plus some PV and mixing kit and a few 18mg eNics from Niceliquid NZ & Vapebar and VapeKing
                                          all done....now I'm totally committed...!!
                                          I'll smoke my face off for the next few days until the parcels arrive...!! πŸ˜„
                                          • soloS
                                            solo
                                            That's what I did, spent an entire months cigarette budget so I had no choice but to vape, and it worked well as I have never touched a smoke since day one. I save over $300 per month and I'm healthier, look better and have acute smell and taste (I used to think kids overreacted to my farts, I sympathize now)
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 41
                                            • 42
                                            • 20 / 42
