    Virtual Dub use with SketchUp
    2 Posts 2 Posters 796 Views 2 Watching
    • S
      susangh208
      Hello-
      Is anyone familiar with Virtual Dub (with codec x264). I am using it for animation. My problem is that when I am processing, I receive an error message "out of memory". In sifting through the internet, learned it may not necessarily be an issue that results in the lack of RAM.
      Or if you have another suggestion in lieu of Virtual Dub? This is needed to stitch together plugins: Proper Animation & Smooth Step for exporting. I sent a note to Twilight Render to see if their software can do this and did not hear back (I don't need the software for rendering...it's "capturing" the work in Proper Animation to export that is the hang up).
      *I very much understand how to export simple animations... its when using Proper Animation, that is the catch.
      Thanks!
        Twillight Render works with the Plugins animation of Sketchup! πŸ˜‰
        You can also use something like the free BBFlashback express for recording the animation on the screen πŸ˜‰
        you can also export your animation as simple images (25 images/ second) then make the animation inside Blender for example πŸ˜„
        http://www.3dsaloon.fr/phpbb3/download/file.php?id=4211&t=1
