    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 63.7k Views 19 Watching
    • PixeroP Offline
      Pixero
      You could try opening it in a texteditor. I use Notepad++.
      Set the language to Ruby and try to find the lines described by TIG.
      • sdmitchS Offline
        sdmitch
        @utiler said:
        Hi Sam, I note above you said you haven't considered converting this plugin for metric use and TIG has outlined how to 'metricate' it. I'm a little unsure how this is done; Do I try and open the script and edit it? A little risky given I nothing about coding....
        Cheers.
        Better leave it to the "professionals". I'll take a look at it and PM you a copy to try.
        http://sdmitch.blogspot.com/
        • utilerU Offline
          utiler
          Thanks for the vote of confidence, Pixero but I'm likely to blow it up.... πŸ˜†
          Just Curious...
            billmorr
            Is it just me or has this plug in stopped working in Sketchup Pro 2017???
            • sdmitchS Offline
              sdmitch
              @billmorr said:
              No it's not just you. SU2017 strikes again. I will try to fix the problem if I can.
              • sdmitchS Offline
                sdmitch
                @billmorr said:
                Face to Frame updated for SU2017 compatibility. Download new version for PluginStore or blog.
                • 4 / 4
