    [Code] User::ToolbarSet collection
    4 Posts 1 Posters 592 Views 1 Watching
    • Dan RathbunD
      Dan Rathbun
      [ Code ] User::ToolbarSet collection
      An example of a universal toolbar set collection.
      (I keep these scripts in a "User" sub-dir of the "Plugins" dir.)
      #  User_ToolbarSet.rb
      #  VERSION ; 2.0.1
      #  An example by; Dan Rathbun
      #  Maintain a Hash of custom Ruby Toolbar object references,
      #  and access them by using their name as the hash key;
      #  Example;
      #  User;;ToolbarSet["Shadow Strings Fix"].show()
      #  You can add new references into the Hash when you create toolbar;
      #  Ex;
      #  tb = UI;;Toolbar.new("Nifty Tools")
      #  User;;ToolbarSet[tb.name]= tb
      #  OR;
      #  caption = "Nifty Tools"
      #  User;;ToolbarSet[caption]= UI;;Toolbar.new(caption)
      #  You can call refresh() anytime to be sure the hash is up to date;
      #  Ex;
      #  User;;ToolbarSet.refresh()
      module User
        ### Hash to hold references to Ruby Toolbar objects;
        ToolbarSet = Hash.new {|this,key|
          # block of code that gets called if the [key] method
          # fails to find a member with the given key argument;
          this.refresh()
          if this.has_key?(key)
            this[key] # return the new toolbar reference
          else
            msg = "Unknown Key '#{key.to_s}' in User;;ToolbarSet hash!"
            puts('ERROR; '<<msg) if $VERBOSE
            raise(IndexError,msg,caller)
        ### Extend the ToolbarSet hash with a refresh method;
        def ToolbarSet.refresh()
          added = 0
          count = ObjectSpace.each_object(UI;;Toolbar){|tb|
            next if ToolbarSet.has_key?(tb.name) && ToolbarSet[tb.name].is_a?(UI;;Toolbar)
            # Otherwise, add it's reference to the hash;
            added += 1
          if $VERBOSE # normally false (can be nil for silent mode)
            if added > 0
              plural = added>1 ? "s" ; ""
              puts("#{Module.nesting[0].name};;ToolbarSet#refresh(); #{added} new toolbar#{plural} added.")
            else
              puts("#{Module.nesting[0].name};;ToolbarSet#refresh(); No new toolbars.")
            puts("  total UI;;Toolbar objects; #{count}")
          end # if $VERBOSE
        ### initially load the ToolbarSet hash by calling refresh now;
      end # module User
      VERSION : 2.0.0 - updated as explained in the 2nd post below.
      VERSION : 2.0.1 - fixed refresh() method next statement, to avoid vicious loop
      πŸ’­
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        Perhaps we can modify the User::ToolbarSet hash's [] method's error Proc, so that it refreshes the hash automatically.
        Instead of line 28:
        ToolbarSet = {}
        which creates a hash that returns nil if the [] method does not find a member with the given key ...
        We replace line 28 with a call using the block form of the Hash::new() class constructor.
        NOW.. whenever the [] method does not find a member with the given key, the block is run:
          this.refresh()
            this[key] # return the new ref
          else
        πŸ’­
        • Dan RathbunD
          Dan Rathbun
          UPDATED code in 1st post to v2.0.0, per 2nd post above.
          • Dan RathbunD
            Dan Rathbun
            UPDATED code in 1st post to v2.0.1, in refresh() method's next statement to avoid a vicious loop. (We use Hash#has_key?(key) rather than Hash#[key]!=nil, because our v2.0.0 update makes the [] method call the refresh method, so we must be very careful from within the refresh method that any [] method call does not cause a unwanted or unneeded, call to refresh.)
