    Residential Exterior
    8 Posts 3 Posters 765 Views 3 Watching
    • R
      Red33
      Here's my latest rendering done for a custom home builder. I used Sketchup for modeling, Vray for rendering and photoshop for the post work. Please let me know what you think!
      • pbacotP
        Nice sharp picture. I like the shadows, curtains and windows. Grass is nice and effective, but so perfect. What was your grass technique?
        • R
          Red33
          Thanks for the comments! The grass was photoshopped for this one.
          • DanielD
            Daniel
            nice image. You need to work on the brick arches over the garage doors. I wish my lawn was that nice!
            My avatar is an anachronism.
            • R
              Red33
              Yeah, I didn't have time to map each brick to follow the arch. Know of a trick to make that easier?
              • DanielD
                Daniel
                You want easy? Make it flat, or install a stone lintel.
                Design the arch (number of bricks, centerpoint of arch, etc.)and map it out with guidelines. Create one brick. Rotate-copy it from the centerpoint 'til you have all the required bricks to make your arch. You may have to adjust your brick texture on occassion. Hide the lines defining the individual bricks. (consider doing this as a separate model, then skip ahead to the last paragraph below)
                On large, more complex arches I've modeled the bricks and mortar separately. But, then, I am anal retentive and crazy.
                If you have a lot of arches without much variation in the brick pattern/color, you might consider saving the arch as a 2d image, cropping it, and then creating a new material to use on all the arches.
                • DanielD
                  Daniel
                  That flat horizontal cornice on the porch gable doesn't look good, in my not too humble opinion. It lacks the level of detail found on the rest of the house.
                  • R
                    Red33
                    Thanks for the input.
