    Count faces by material?
    3 Posts 2 Posters 259 Views 2 Watching
      draftomatic
      Hello everyone.
      Just wanted to ask if there's already a routine out there to count the faces in a model by material or material name. I can write it myself but I thought I'd ask if there's already a plugin that can do it since I just need it to debug a model.
      Thanks!
      EDIT: Let me clarify that it should get all entities, including those inside components (i.e. should look at every face in the entire model), and should also search upward for parent materials for faces that are nested in groups (i.e. if a face has the default material but its parent has the material in question, it should be counted). So it's a little tricky but still seems like something someone out there must have done before.
      • Dan RathbunD Offline
        Dan Rathbun
        This post has code:
        • New Material Methods! (With bugs 😞 )Do not forget to check the back_material
        I'm not here much anymore.
          draftomatic
          Thanks Dan.
          I'd be willing to bet that save_delete_material method doesn't actually search all the faces, only those in the top-level definitions. I had thomthom help me a long time ago to write a recursive function to iterate ALL the faces, so I think I'll piece this together from that...
