    Help with .followme
    7 Posts 3 Posters 448 Views 3 Watching
      dacastror
      Hi guys, I am making a plugin where I need to use .followme and I'm having bug splat with some curves, an attached two example curves that give me problems
      curves
      here a fragment of my code
      model = Sketchup.active_model
      sel = model.selection
      ent = model.entities
      selec = []
      selec.clear
      sel.each{|ob| selec.push(ob) if ob.is_a?(Sketchup;;Edge)}
      if selec.size == 0
         UI.messagebox "Please select a Curve"
         return
      radio_tubo = 10.0.cm
      lados_tubo = 8
      pts=[]
      pts.clear
      pts=selec[0].vertices.collect{|v| v.position}
      if Sketchup.version.to_f < 7.0
         model.start_operation("Draw tube")
      else
         model.start_operation("Draw tube", true)
         grupo = ent.add_group
         entities = grupo.entities
         normal_cir = (pts[0].vector_to pts[1]).normalize
         circle = entities.add_circle pts[0], normal_cir, radio_tubo, lados_tubo
         cara = entities.add_face circle
         cara.reverse!.followme selec
         #selec.each{|edge| edge.erase!}
      model.commit_operation
      qq="OK"
      I try to test the plugin TubeAlongPath.rb with radius = 10 cm and also the bug occurs
      plugin
      I've noticed that with smaller r no problem (for example r = 2 cm)
      I do not know how to fix this, in advance thank you for your help
      (google translator)
      • Dan RathbunD Offline
        Dan Rathbun
        entities.add_circle does NOT return a Sketchup::Curve object.
        It returns an Array of Sketchup::Edge objects, that make up the curve.
        So line 27 should be:
        edges = entities.add_circle( pts[0], normal_cir, radio_tubo, lados_tubo )
        ... and line 28:
        cara = entities.add_face( edges[0].curve )
        I'm not here much anymore.
          dacastror
          Thanks Dan, I modified my code.
          My problem persists, someone can see the problem?
          • sdmitchS Offline
            sdmitch
            Your problem in not so much your code but the curve itself, 320x0.42cm segments. Reducing the number of segments or scaling the curve up 100x worked without Bug Splat. Also reducing the circle size to 1cm worked as well. The 10cm circle is just to big for the curve.
            http://sdmitch.blogspot.com/
              dacastror
              Thanks for the reply sdmitch, give me a first clue
              what worries me is that the user of the plugin do this and generate a bug splat on, I would like in this case simply do not tube, but do not understand how to calculate the minimum length allowed for this case
              • sdmitchS Offline
                sdmitch
                It is probably more a function of the angle between segments than the length of the segments. In this case, the maximum radius is something between 4 and 5cm.
                  dacastror
                  you sent me on the right track, thanks sdmitch
