    Adding items to an existing sub menu
    4 Posts 2 Posters 430 Views 2 Watching
    • sdmitchS Offline
      sdmitch
      In an attempt to get better organized, I was attempting to create a submenu and add items to it using this code
      # ------------------  MENU SETUP ---------------------- #
      unless $sdm_tools_menu
      	$sdm_tools_menu = UI.menu("Plugins").add_submenu("SDM Tools")
      unless file_loaded?(__FILE__)
      	$sdm_tools_menu.add_item("Plugin Name") { SDM;;Module_Name.main }
      	file_loaded(__FILE__)
      I created a two dummy plugins and loaded them using the Ruby Console with load 'c:/.../dummy1.rb'
      I check the plugins menu and the sub menu has been created and the item added.
      I repeat the load process for dummy2. I know it loaded because I can execute it from the Ruby Console but it was not added to the sub menu.
      To complicate the situation, if I copy the dummy plugins to the Sketchup Plugins folder and start Sketchup, they are both in the sub menu. So what's the difference?
      http://sdmitch.blogspot.com/
        Jim
        @sdmitch said:
        so what's the difference?
        Time. The references to the sub-menus are only available for a short time.
        Dan can probably tell us why, but that's just how sub-menus currently work. No way around it, unfortunatly.
        • sdmitchS Offline
          sdmitch
          So even though the global variable retains lts value, the entity it references doesn't exist?
            Jim
            I don't know the internals. But as yoou noticed, even when the global variable appears to reference a valid menu object, new items are not added after some short amount of time.
