    Update on a couple of Mac issues
    1 Posts 1 Posters 1.2k Views 1 Watching
    • W Offline
      willeykj
      I was messing with the code today and wanted to pass on some things that need to be edited to keep SP working on the Mac
      1. the Sound problem
        newer versions of OS X changed the sound APIs so you have to do an edit on the dls_synth.rb file in order for SP to keep working
      To to the Midiator/Lib/Drivers directory and edit dls_synth.rb
      find module AudioToolbox and make it look like this:
      module AudioToolbox
      extend DL::Importable
      dlload '/System/Library/Frameworks/AudioToolbox.framework/Versions/Current/AudioToolbox'
      dlload '/System/Library/Frameworks/AudioUnit.framework/Versions/Current/AudioUnit'
      ComponentDescription = struct [
      1. Joint Settings contextual menu doesn't work
      If you select a joint and right click you will get a contextual menu with " Joint Settings" at the bottom.
      This should open an inputbox where you can set Joint Parameters
      It doesn't work and throws an error in the console about a missing method.
      Edit the JointTool.rb file and change the definition of the setJointSettings method
      find:
      def setJointSettings()
      to
      def self.setJointSettings()
      1. Issues with colors in the dialogs obscuring text
        Edit the controlpanel.html file in the SketchyUI directory and comment out the .css links to simplify the UI
        To comment out HTML you use the HTML comment tags: <!-- -->
      Alternatively, you can simply delete the 2 lines
      Here's what you're looking for:
      <link href="sketchy.css" rel="stylesheet" type="text/css">
      <link href="default.css" rel="stylesheet" type="text/css">
